Question about Toshiba 27A62 27" TV
TV won't power ON
When  I turn the set on I hear a clicking sound and the pwr LED on front comes on but no picture comes on.  From then on I get the same symtom every 5- 10 seconds, after a couple of hours the set usually comes on.
The other symptom is that I can not stop the set from trying to turn on unless I pull the pwr cord from the wall receptacle
  • 905 Answers
This problem will need to be repaired , it is most likely the EPROM chip or controling circuts
Posted on Oct 09, 2008
Hitachi 65SWX20B no picture/sound, 4 out of 5 green LEDs on, red LEDs on, green B+ LED is off. Pwr Relay clicks on, TV only turns on/off. IP02 location/How to check for 14-20V on terminal 4 of IP02?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 20, 2016 | Hitachi Televison & Video
When I push the power button on the tv I hear a click and then another click but the tv won;t turn on. The white led on the front comes on momentarily the goes out. I have replaced the power suppy boa
sounds like a capacitor sometimes they look fine but don;t work. I had this problem in my lg replaced 3 caps and it fired up. caps are cheap.
Jan 23, 2015 | Televison & Video
50" Philips Plasma 50pfp5332D/37 won't turn on
I have a 42in vizio led with about the same problem i replaced a 75 cent chip # u33 on computer board problem fixed.
Sep 25, 2012 | Philips 50PFP5332 50" 1366 x 768 Plasma...
Set worked fine when turned off. Now nothing happens when pwr button is pressed. Timer light does not come on. If system reset button is pressed, pwr led flashes for 60 secs. System is still dead. Status...
If your tv is around 2-4 yrs or used 6000-8000 hrs,never replaced the lamp before it could be time to replace it.If you hear strange noises like buzzing or humming noises it could be the color wheel which is a little disc that has a gamma of colors and spins at high rpms.When the light of the lamp goes through it creates the colors on your tv.The other most common failure is the board that powers the lamp,which is called the ballast.When its bad it will make a clicking sound or like wanting to turn on. For parts you can find them in partstore.com shopjimmy.com or discount-merchant.com God bless.
Feb 09, 2010 | Mitsubishi WD-65732 65" Projection HDTV
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
NO PICTURE, NO SOUND On My Plasma TV.
Should have been 3300 UF 10V caps that were bad? Shouls have been replaced with 3300UF 18V. 50V is huge. If it was replaced with a 50 the polarity may be wrong or the cap it too big to be seated property. Sometimes the caps just dry out and even a normal looking one will be the culprit of no OSD. Are you getting an LED fault code blinking? That should be a red led. Do you hear the relay clicking.? When you replaced the caps did you charge them? Just plugging in the set without trying to power it on for about 20-30 mins. I may be able to help you
gysgt2u1@yahoo
Mar 05, 2009 | Philips 50MF231D 50 in. Plasma Television
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
solutiondoct
Nov 06, 2008 | Televison & Video
Tv wont work
does the power indicator blink? If so how many blinks? also do you hear any sounds when you press power?
Aug 09, 2008 | RCA P52926 52" Rear Projection Television
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
No sound no picture
Does any lights come on led on front of set? Does set make any squealing sound when you press power? If not then open and look at power supply board. This is the board that the cord is attached too. look for open fuse, check 2004, 1000, 1300, 1900, etc. See if fuse blown then look for short in pwr. supply.
Aug 29, 2007 | Philips 60PP9202 60" Rear Projection...
Toshiba 27A62 27" TV Logo
196 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
