Question about Rio Forge Sport Digital Media Player
Error Message When i try to start mine up it says "UPGRADER", and it won't connect to the computer because it can't turn on. Anyone know what to do?
Had this trouble 2 times.. remove battery and let it sit for about 30 min...
Then install battery if no better than reinstall firmware.. V 1.33
Posted on Nov 17, 2007
Rio Chiba Upgrader Error
my rio carbon had the same problem and displayed upgrader all the time if it helps what i did was i cf modded my rio carbon look on google and see if your rio chiba can be cf modded and if that works that would be pretty cool and remember if you have any tech problems or mp3 problems google it and google usually will have an answer have a good day
Feb 07, 2012 | Rio Chiba Street MP3 Player
Upgrader
can u upgrade the firmware and software uuse for it from the website maker ok save the update sto the hard drive then installl
Jan 26, 2008 | Rio Cali Sport MP3 Player
Rio carbon player does not start it reads UPGRADER. I tried resetting needle in hole but still reads UPGRADER
try puting a cf card in it or look up problem on google if this doesnt help hold in menu and power for 4 seconds see if this helps in undoing the upgrader message if not try connecting it to a windows pc with xp or 7
Aug 13, 2011 | Rio Carbon MP3 Player
I turn it on and it says "upgrader" and then turns off. It's done this before and I thought when I hooked it up to the internet or whatever it corrected this problem. I connected it to the computer and the...
This means you are currently in the "upgrader mode". Please turn the unit OFF and then back ON. You can download the latest firmware version of your player. Please be advised that downloading firmware update may delete contents in the memory of your player. You can also Flash the memory by removing the batteries, wait for a few seconds, and put it back in.
If this doesn't work, and if the player is detected by the computer, try to reformat the player (this will erase all the information from the player).
Nov 19, 2009 | Rio Forge Sport Digital Media Player
6 gb version of H10 displaying error message on start up
you need to upgrade firmware to version 2.51 using the mtp upgrader download found at www.iriver.com-support-ask.asp after doing this your player should work this upgrade is a recovery tool and works very well with all mtp version players
Dec 30, 2007 | iRiver H10 MP3 Player
Error Message on start up
go to this page, http://rcaaudiovideo.com/en-US/RD2780_Upgrade and follow the instructions, i had this same problem, and i fixed mine
Apr 12, 2007 | Thomson Lyra PDP2860 Digital Media Player
Rio carbon saying "upgreader"
im not sure it'll help but something told me when mine said the same thing that the device needed a new driver. what ever that is.
Apr 10, 2007 | Rio Carbon MP3 Player
My Rio says upgrader when I turn it on
UPGRADER is a mode that purges the firmware from the Rio player prior to flashing the unit. Firmware is basically the operating system for the player, so if it is corrupted any number of things can occur. You can enter UPGRADER mode to update the firmware on your player by holding down the MENU button when you power the Rio ON. Flashing the player in this mode erases all content. Try the following to get the unit out of UPGRADER mode, if powering OFF the unit will not correct it. ALL PLAYERS - If you accidentally entered UPGRADER mode, turn the unit OFF and then back ON again. - Download the latest version of the firmware for your player and upgrade the unit. Visit http://www.digitalnetworksna.com/support/rio - It may be necessary to run the firmware update more than once. - This process may erase content from your player. - If the player is detected by the computer, it is recommended that you format the player, which WILL erase content from the player. - Macintosh user's try flashing the player on a PC. FLASH MEMORY PLAYERS - Remove the battery and replace it, this will reset the unit. The Rio Forge, Rio se510, Rio Cali [Black Rio Stick], and Rio Chiba [Black Rio Stick] can lock up causing the player to be unresponsive. If this occurs there are two things that need to be performed to resolve the issue. First you want to remove power from the player this includes the battery and a USB connection for 20 minutes to reset the player. There is a capacitor on the player that stores a charge that holds the player in the locked state. By waiting the duration the capacitor will discharge and the player should function as normal. Second you will want to upgrade the firmware to the latest version and format the player to prevent future occurrences. HARD DISK DRIVE PLAYERS - If you have a Carbon, Nitrus, Eigen, or Karma, use a paper clip to reset the unit. Your Rio will power off automatically when it has been reset. It may be necessary to connect the player to AC power and then reset the player if it will not turn on. If you are still unable to have the player exit UPGRADER Mode, then try it on another computer. UPGRADE FIRMWARE - Connect to the internet - Go to http://www.digitalnetworksna.com/support/rio/ - Click on the appropriate player - Click on the FIRMWARE tab [showing by default] - Click on the latest firmware file [example: RioForge_firmware_133.exe] - Click SAVE when prompted - From the SA
Feb 14, 2007 | Rio Forge Sport Digital Media Player
Dropped it once and now it's completely unresponsive
I apologize this isn't a solution but I wanted to let you know that I dropped my Rio Carbon player this morning at the gym and now mine won't do anythin either. I reset the player and then I received a display message of 'upgrader." Per the websites instructions i tried to install the most recent 'firmware' and it still does nothing. When it restarts itself it goes right back to displaying 'upgrader' I installed the firmware software a few times per the instructions and still nothing has happened :( I am sad and frustrated at the same time--mine was maybe used a dozen times. I hope we get some feedback to our problem--and again I apologize I didn't post the solution. Jill
Jan 09, 2007 | Rio Carbon MP3 Player
The screen says "Upgrader"
Have you upgraded the software if not try that. Check your battery voltage if it reads around the 2. something voltage then you need to get that battery to its orginal capacity. I dont think you'll get your songs back. Does it have a reset button if so reset it.
Jun 10, 2006 | Rio CE2100 MP3 Player
Open Questions:
Rio Forge Sport Digital Media Player Logo
35 people viewed this question
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Marvin
Marvin
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
