Question about Dyson DC44 Animal Digital Slim Cordless Vacuum Cleaner
Dyson will not start
Pull trigger light flashes even on a full charge and a new battery
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
The Dyson DC35 (and probably other) battery packs appear to have a 15Amp fuse in the negative lead inside the battery pack. I opened my battery pack (not a job for the faint-hearted) and found the item that looks like a resistor (I'm an electronics tech) marked 15A was open circuit. I replaced it and the DC35 is working again.
Posted on Apr 20, 2017
  • 1,511 Answers
If the power cells are operational and it will not start; then either the motor is dysfunctional or something is jammed in the intake module. A conduction test with instrumentation can indicate if the motor is the problem, the power cells are not fully charged, or you have a short circuit. Check Fuses.
Posted on Feb 27, 2014
4 Suggested Answers
ThinkVacuums
  • 144 Answers
SOURCE: Hi, this is our third Dyson DC-16.. the Trigger
How are you charging your battery? Every battery has a memory. If you dont let it die the first come times then charge to full the battery will assume 40% is 100%.
Posted on Oct 23, 2009
Testimonial: "Thank you for your solution, but we've had it at least a year.. it stays on charge when not in use.cleaned the connections.working better, not 100%.."
SOURCE: i have a dyson dc16
it needs charging . and if the lights dont light when you put it in the charger somthing is wrong with charger or battery
Posted on Oct 24, 2010
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: We push the trigger, and the light comes on but no suction/ motor not working
    I'm sorry to hear you're having difficulties with your DC35. From what you've described, it sounds there may be a fault with one of the components of your machine. If you give our Helpline a call, we should be able to help - you can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US). Please have the machine to hand when you call so we can run through some troubleshooting over the phone with you.
    We'll look forward to helping you resolve this issue.
    Best wishes,
    Jack
    Dyson Online Customer Support
    http://www.dyson.com
    Posted on Mar 15, 2012
    I have a new Dyson V8 Absolute When I try to charge it nothing happens. When I pull the trigger I have one flashing blue light. HELP
    not trying to be a smart a** but which of the two do you have?
    1. A flashing blue light indicates that the battery is running low on charge.
    2. A fast flashing blue light indicates no power or a temporary fault (e.g. check filter or for blockages).
    FYI....A solid blue light indicates that the battery is charging. No light indicates the battery is fully charged. A solid amber light indicates that the battery is not charging due to a temporary fault (e.g. too hot/cold). A flashing red light indicates that there is a fault, call the Dyson Helpline.
    Best to you.
    Feb 20, 2018 | Dyson Vacuums
    My new Dyson Serial Number PM8-US-HHB1494A will not charge.
    Suspect a dead battery or a defective charger
    Dec 28, 2016 | Dyson Vacuums
    Dc31 flashes green
    Hi there, it's Jack at Dyson.
    Usually if the indicator light flashes green when the trigger is pulled, this means the machine needs to be charged. If you have had your machine connected to the charger assembly for over 3.5 hours and continue to see the flashing green light, this could mean the machine isn't recharging correctly.
    In order for us to diagnose which part is at fault we'd need to take you through some simple diagnostic checks when you have your machine to hand. You can reach our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    We'll look forward to speaking with you.
    Aug 03, 2014 | Dyson DC31 Bagless Handheld Vacuum
    Light blinks when i pull trigger
    Hi Philip, it's Jack at Dyson.
    If you've recently replaced the battery and ensured it's fully charged, and you're still noticing a flashing indicator light, there may be a fault with the main body assembly.
    We'd like to take some further details to confirm if this is the case. If a replacement part is required, we can also check whether this is covered under your vacuum's 2-year warranty.
    You can reach our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). Please have your machine to hand when you call so we can run you though some quick diagnostic checks.
    Feb 26, 2014 | Dyson DC44 Animal Digital Slim Cordless...
    DC44 Animal Cordless Vacuum power cuts on and off while trigger is pulled
    This doesn't address the intermittent power cut offs...power cuts off intermittently and you have to keep recycling the power 'trigger' to get it to work...total PIA
    Dec 17, 2012 | Dyson DC44 Animal Cordless Vacuum
    Dropped off countertop. Will not work now. I have bottom Red and two green lights flashing ??? I have had the battery on the charger< and had it tested. The battery is full charged but still will...
    There is a small magnet on the pre- filter that triggers a switch. Pull it apart and you'll see the magnet but the switch is behind plastic.. Make sure it is seated well against the motor unit.
    Jan 13, 2011 | Dyson DC16 Root 6 Bagless Handheld...
    Hi, this is our third Dyson DC-16.. the Trigger was shorting out on the first two.. Now we have the third one for about a year.. on charge when not using it.. don't use it every day, but for quick pickups...
    Oct 23, 2009 | Dyson DC16 Root 6 Bagless Handheld...
    Dyson DC44 Animal Digital Slim Cordless Vacuum Cleaner Logo
    411 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
