Computers & Internet Logo
s
sarala natarajan Posted on Feb 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It is not cleaning my computer
It is not clearing the errors on my computer. When it will start clearing?
Stephen Kamm
Level 2:
  • Expert 69 Answers
  • Posted on Feb 26, 2014
 Stephen  Kamm
Expert
Level 2:
Answers
69
Questions
Helped
17344
Points
109
Try using free software from File Hippo.com CCleaner plus Glarys Utilities and Slimcleaner. That should do the trick.
2answers
How to fix the waste toner cartridge error on a xerox 6505DN printer
Hi, check out the forums on this model, but you will be frustrated.
This is usually an error when a non-Xerox certified toner cartridge is used. If you can, try to get an original Xerox toner cartridge and see if the error clears. If you know someone else who has a working cartridge you can use that, to see if the issue clears.
https://forum.support.xerox.com/t5/Printing/Phaser-6500-quot-Waste-Full-Black-Cartridge-quot-error-message/td-p/22999
2answers
How to fix 0xc000007b problem
This Microsoft Office error code occurs when you are updating installing and copying etc. This error occurs due to router and modem configuration and ISP restriction.
This error can be solved in 4 ways
1. By cleaning temp folder
2. By cleaning the %temp% folder
3. By cleaning the system file
4. By cleaning the Internet Explorer junk
Guide to solve your issue
Open the Run by pressing the window + R keys
Then open the temporary file system location by searching the temp in command prompt
If you have files means then select all the files and clear them by pressing Shift + Delete
This is also similar to clear the temp folder. By this method, we clear the user junk files.
Instead of temp search as %temp% in command prompt and follow the above steps.
Open the Run command prompt
Enter the cleanmgr command
Then select the drive which one want to clean
Then scan for junk data after that choose the entire item from the list except the recycle bin to clean.
Open the run window and enter the inetcpl.cpl command
Then go to advanced tab and select the reset button to clean the junk data
Then you will get pop up to delete the personal settings click ok to delete.
By following the above steps you can resolve your windows error code issues. For further more guidance regarding windows, you may visit the Microsoft Support Number.
How do i get the cartridge games to start on this little computer
Clear the system cashe and do a disk clean up then a defragment after that find a program on the computer to check disk drive then repair it if error comes up most anti-virus programs have this
Run time error 75 path file access error
You should try to clean boot the system to see if the problem clears up.
Follow the steps below to place your computer in "clean boot"
  • Click the Start on your Desktop
  • Type msconfig in the Start Search box, and then press ENTER.
If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
  • On the General tab, click Selective Startup.
  • Under Selective Startup, click to clear the Load Startup Items check box.
  • Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
  • Click OK.
When you are prompted, click Restart.
When the desktop loads, test again and see if you still receive the error.
If this does resolve the issue
then to set your computer back, to boot normal:
  • Click the Start orb on your Desktop
  • In the Start Search box. Type msconfig, and then press ENTER.
Click the General tab.
  • Click Normal Startup - load all device drivers and services, and then click OK.
  • When you are prompted, click Restart to restart the computer.
1helpful
2006 Ford Taurus Charging error message and Battery light
What error message are you receiving? If you are talking about your check engine light (CEL) then you will need to clear the codes for it to go away, or it must be driven through a series of specific events for the computer to clear itself, just take it down to your local auto store and have them scan and clear codes. At 14.5v you should not get the battery light, you may want to check your wiring to your ECM. With your old alternator running at 16v I would say it is possible something was damaged. I know many manufacturers do not protect the computer from spikes from alternators, I have seen this twice in the field, and actually had personal experience as well. This will require much more knowledge about your vehicle and electricity to understand what pins to test and what you should be looking for.
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
PoweReadACValue error
Probably it is cause due to power management system corruption
Try following steps
Perform a Clean Boot
If your computer is not starting normally, or if you receive errors when you start your computer that you cannot identify, you could consider performing a "clean boot." This operation starts the computer by using a minimal set of drivers and startup programs. This can help you troubleshoot the problem.
Method :Perform a Clean Boot
Step 1: Start the System Configuration Utility
1. Click Start, click Run, type msconfig, and then click OK.
2. The System Configuration Utility dialog box is displayed.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box. Verify that Load System Services and Use Original BOOT.INI are checked. 5. Click the Services tab.
6. Click to select the Hide All Microsoft Services check box.
7. Click Disable All, and then click OK.
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. If you are prompted, log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK.
Note: Start Windows in Normal State
Steps to configure Windows to use a Normal startup state
After you used the clean boot to resolve your problem, you can follow these steps to configure Windows to start normally.
1. Click Start, and then click Run.
2. Type msconfig, and then click OK.
3. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
4. When you are prompted, click Restart to restart the computer.
Computer extremely slow and periodically it shuts down with a fatal error. We've tried emptying the Temp files and cleaning out our hard drive. If I recall, the problem started soon after installing an...
Clean Windows Registry :
Defragment your PC to increase computer speed:
Add more RAM to Speed up your computer
Clear Cache, history and temporary internet files
Turn off unnecessary programs from start up:
Have low intensity graphics
Uninstall unused software and programs Please remember to clean Windows registry using registry cleaner reg in out The above guidelines were really helpful to speed up my computer. These are safe and do impact computer performance in a positive way.
4helpful
3answers
Paper sizing error
Solution #2 WORKS! Just when you use the #clear option.. select "ALL" it will reset everything but all you have to do is simply re set the paper size to letter as it seems to default to A4 size once it re-initializes. What a nightmare this was..
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
