Question about O2 Xda II mini
O2 mini power problem
My phone turn off or restart when the power indicator around 80%,still got the problem after a week when i change a new battery.but if i plug in the charger,its ok..is it caused by phone hardware,software or the battery pack?
I had the same problem. My phone will keep freezing once the battery goes below 75%.
It worked fine as long as it was connected to the usb.
After a battery change, everything was back to normal.
Posted on Dec 19, 2007
    Problem Solver:
  • 11 Answers
Could be either one - is your battery connection loose or anything if not ask o2 about it
Posted on Nov 30, 2007
SOURCE:
4.3 lost all power will go to about 2000 rpms if you hit the gas harder the rpms will fall
NOT IF ENGING STILL RUNS. ALL WAIST CHECK FUEL PRESURE GM HAD CPI, PFI SO MAKE SURE YOU HAVE THE CORRECT PRESURE CENTRAL PORT INJECTION WILL NEED 80 PIS. 1 INJECTOR AND 6 NOZALS. OK THAT FUEL THE OTHER IS A PLUGGED EXHAUST. EASY PULL THE O2 AND SEE IT ENGINE REV UP ,IF IT DOES CHECK CATALITC CONVERTER
Jan 19, 2013 | 1994 Chevrolet S-10
My O2 XDA mini II gets truns off oftenly , it is not action specefic but ot gets turns off i have to press top right side button and again to startsm please provide solution is this problem in OS or...
It does not turn off.
It gets into the sleep omde.
No need to worry man,
its just to save power.
All windows mobile phones do the same when left for sometime.
Keep cool .
Please Rate.
Oct 11, 2008 | O2 Xda IIs Pocket PC
Xda mini S Pocket PC problem
your phone is being reset if the situation is like that. get your pen and push the button beside the charging socket and press the power button also simultaneously.
May 22, 2008 | O2 Xda II mini
Problem with o2 mini
I had the same problem b4 it turns out my speaker pin is broken. U have to buy a new speaker coz u can't solder back the pin once it's broken. Just buy the speaker and change it yourself, it's really really easy trust me. I've done it b4, I can show u how to do it.
Mar 05, 2008 | O2 Xda II mini
O2 XDA Keep on Restarting
put the foil paper or what ever that can fit the hole in the
low right hand side of O2 mini looking from the back
the hole (just right over the red rubber thing named "pull")
just put sth that fit the hole and close the lid and then
prevent the lid opening by putting some scotch tape on
problem solved
just keep the lid close to prevent the thing we put in the hole fall out
that's all
(the thing in the hole is to pushing the switch inside the hole)
good luck
Oct 30, 2007 | O2 Xda II mini
Call disconnected when battery around 60%->80%
might be a problem with battery of phone so try by changing battery or consult ur service  provider abt. network signals at a particular time or try by inserting stylus lightly at the hole at bottom corner of ur handset .
gizmo 1
Oct 11, 2007 | O2 Xda II mini
O2 Ice
o2 ice restart problem
Sep 23, 2007 | O2 Xda II mini
XDA Mini II won't advance past the align screen
refert to this, it may help: http://forum.brighthand.com/showthread.php?t=217656
Sep 14, 2007 | O2 Xda II mini
My O2 XDA II mini restarts continuously
try changing your phones cover!!!
Aug 26, 2007 | O2 Xda II mini
O2 getting restarted often
The reason is the back pannel of your O2 has a switch. Iff you notice just next to the Battery pack you might have a small switch which it wil trigger the device to turn off and on the latch must lock when the pannel is closed. If that switch can be closed by a paper then it wont switch off.
Apr 18, 2007 | O2 Xda II mini
Computers & Internet Logo
98 people viewed this question
Top O2 Computers & Internet Experts
xxxxxx xxx
Sheldon Dedek
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
