After a short power outage, dishwasher doesn't come on, no lights, no noise. there us no blown fuse or a tripped circuit breaker. We turned it all off and on again. All other appliances are working fine. GE said it was an act of nature and to call an electrician. Is there anything else we can do? Thanks.
SOURCE: Dishwasher tripping the circuit breaker
Andy, leave the breaker off and remove the toe panel (bottom panel) from the dishwasher. Remove the cover of the junction box where the cord connection or wiring is made. Look at the wire caps and see if they are not burnt. Sometimes these connections become loose and arch, tripping the breaker. If so, cut the wires, strip a new end and reconnect. Catriver...post back.
SOURCE: KitchenAid dishwasher is dead
yep, u can use an ohmmeter to test a fuse.
I think uve found the problem .
Good work
Cheers
JigSaw
SOURCE: GE 2200 Dishwasher-no power at all, circuit breakers are fine, switch works
with your volt/ohm meter check for power going to the dishwasher. the power supply is located under the kick panel. the power wire may be shorted out due to poor installation. if you are not comfortable testing power, I would advise calling a professional. If no power is found at the power box (this has a power cord or electrical wire going to it) the problem lies within your house electric. if 120 volts is present, check for power @ the door switch. aftrer that you just need to follow the power wire and see where it stops
If this is a newly built house and new to you the builder may have put a light switch above your counter ,the one you didn't think went to anything, check for that! good luck with it!
SOURCE: Dishwasher tripping fuse box
Has the door got any heavier, as mine started tripping the electrics when a spring broke and short circuited the connections.
f so you will have to get the spring out, from the underneath is best and replace it if you want the door to work correctly again. On mine the second one went a month later.
SOURCE: Dishwasher tripped our main circuit breaker.
It may be that your water pump is leaking on to the motor...
If you find the fuse blown or circuit breaker tripped, unplug everything from the circuit to which the microwave is connected (keep in mind that other outlets may be fed from the same circuit). Replace the fuse or reset the circuit breaker. If the same thing happens again, you have a problem with the outlet or other wiring on the same branch circuit. If plugging in the microwave causes the fuse to blow or circuit breaker to trip immediately, there is a short circuit in the power cord or elsewhere.
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
Assuming these are not your problems, a fuse has probably blown although a dead controller is a possibility.
While you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, go to the link at the top of this post.
