Error c94 still
SOURCE: sir i have toshiba e studio 163 my machine
u have installed a toner that is not original ,,,try to put an original toner ,,,and then try or let this toner get empty and then try the original one,,,,
SOURCE: how to solve a problem error code c44 e studio 163
C44 Abnormal fuser after abnormality judgment
1,2.3. Check the thermistors, IH control board, IH coil and LGC board
Check the above components following the procedure 1, 2 and 3 for [C41].
4. Clear the status counter
Change the current status counter value (08-400) “4” to “0” for [C43] and “5”, “7” or “9” to “0” for [C44], taking
the same procedure as that for [C41].
* The status counter value is as follows in the following cases. Change them to "0" respectively.
• The error occurred during warming-up: "4" or "5"
• The error occurred after the machine has become ready: "6"
• The temperature detected by the center thermistor is 230°C or higher: "9"
• The temperature detected by the side thermistor is 270°C or higher: "9"
SOURCE: how to use e studio 163 on windows 2008 os
How u connect your MFP, via USB or network?
If USB, viewer 2 is not supported on window 7 & 2008. If networking, u can try the minidriver.
SOURCE: My e-studio 163 copier indicate code error c44 and
Hi how are you this is jack ([email protected])
your copier show error c44..
Dear you press 0 and 8 key simantenasly and On copier other hand.. copier panal show ..AJ.... after 1min AJ constand.. then you press 400 and Start key.. your copier show one value 5.or.6 or.7..every x.y.z ok.. Then you press 0 key and press intrept key.
COPIER REVERSE AJ MODE THEN OFF COPIER..
AND simple ON Copier.
DEAR PLEASE VOTE ME.
Thanks ,
Best Regards,
Testimonial: "it was perfect and many thanks"
SOURCE: my e-studio 163 copier indicate code error c44
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(3) Check if the thermostat is blown.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
3. Check the LGC board
(1) Check if the connectors CN316 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
please vote me.
Thanks
Best Regards
