Question about Jensen LXA300 Car Audio Amplifier
No low bass
I have two JL Audio 12's in my 2004 Yukon with a LXA300 Jensen amp. I am having trouble geting low bass I've played with my EQ but my speakers bottom out when low freq. hits? What causes speakers to bottom out?
Get a bigger amp. or smaller subs!!!!
Posted on Mar 19, 2008
What type of box are you using and what size? A sealed sub-box will give you more hit and more bottom end but drops off on higher frequencies. A ported box is much more efficient and has less drop off at different frequencies but is much larger, but with a Yukon you probably don't have to worry about the size of the box.
Posted on Mar 05, 2008
  • 631 Answers
Check the wiring of the woofers. If one speaker is wired improperly, it can cause the loss of bass and will make the woofers bottom out easily. Check inside the enclosure at the terminals and at the speaker.
Posted on Oct 29, 2007
Have 8ohm svc how do you wire to jensen lxa300 watt amp
DON'T you'll kill the amp.
Cars use 4 ohms or sometimes 2 with dual voice coil subs.
Apr 16, 2017 | Jensen Car Audio & Video
I want to no the ohms of Jensen LXA300 2ch. 300w amp
Specifically it's 50x2 rms at 4 ohms stereo, 75x2 rms at 2 ohms stereo, and 150x1 at 4 ohms bridged.
May 23, 2011 | Jensen LXA300 Car Audio Amplifier
I cant get my jl audio w6 10s to give off much bass with the jl audio 500/1 amp
here is a manual for your subwoofers: http://mobile.jlaudio.com/pdfs/8-12W6_BDS.pdf
use the wiring diagram for 1.5? (1.5ohm) with 2 speakers. the diagram for 3 speakers will not work, because it would bring the load down to 1 ohm, and the amp cannot go below 1.5 ohm.
to set up the amp:
under "preamp output section", on the "output mode" switch, select "amp filter"
to set up the levels: start with the amp gain pretty far down- with the input voltage on low for line level outputs from the deck, and on high for speaker outputs from the deck. now turn your cd deck as far up as it will go until it distorts, then turn the cd deck down to just where it stops distorting. now, you can start to turn up the gain on the amp.
on the filters, youll prolly want the cutoff filter around 100hz @ 24db slope. start with the infrasonic filters off, but, if you do get into them, try centering between 30 and 60hz on either, and, possibly dropping the cutoff filter to 80hz.
Jan 31, 2011 | Jl Audio 500/1 Car Audio Amplifier
No problem just need advice
if you use for bass need to adjust to a 120Hz in the amp & eq
Apr 26, 2010 | Performance Teknique ICBM-772 Car Audio...
Want too get best low bass i can from this amp
you turn your low pass filter (LPF) on the amp down to your desired frequency, but the box you have it in will drasticly change the sound (if you werent aware) hope this helps!
Mar 22, 2009 | Jl Audio 500/1 Car Audio Amplifier
Complicated JL Audio Amp
1. set the amp LP filter frequency at about 80hz and mode/slope to 24db.
2. set the amp gain as recommended in the manual.
3. set the subsonic to on and to about 25hz
4. ste the bass eq to off!
5. set the input voltage to low and signal sensing to off
6. Fine tune by ear.
Oct 28, 2008 | Jl Audio 13W7 Car Subwoofer
Should I use this Jensen LXA300 AMP to power my DS930 kicker 6x9's
i have a 2 channel boss amp running my 6x9's & a candence 2 channel on my bass ..they say for ur mids & high's a 4channel is best , but i like the 2 channel better ... so i think u wil be fine with the amp uhave , just be sure 2 tun it down so it wnt blow ur 6x9's...
Oct 02, 2008 | Jensen LXA300 Car Audio Amplifier
Amp settings
It's going to be mainly "what sounds best", but I'll give you a start.
  • Set the gain to 50%.
  • Set the LP filter to 12db at about 80Hz.
  • Set the infrasonic filter to ON and at about 20Hz.
  • Set the Bass EQ to ON, Q to 0.7, center freq to 40Hz, and boost to about 5dB.
The other settings are going to be based on how the system is connected to the head unit.
Mar 22, 2008 | Jl Audio 500/1 Car Audio Amplifier
Alpine
If this occurs with the head unit plugged directly into the amp (no signal processors inline, you probably have open shields on the head unit.
To check the shield ground, disconnect all RCA cables from the head unit and measure the resistance between the RCA shield on the head unit and the case of the head unit. It should read ~0 ohms.
Dec 03, 2007 | Car Audio & Video
Jensen LXA300 Amp. need to known specifications of electron. part
If you remove the clamp, there will be a part number on it. Post the numbers on the transistor and we'll go from there.
Mar 15, 2007 | Jensen LXA300 Car Audio Amplifier
Jensen LXA300 Car Audio Amplifier Logo
240 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
