No, don't use a convertor. Please buy a SATA PCI addon card.
like this http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=pci+sata&x=0&y=0
the above card will do alot better job than a converter, if you don't have sata and you don't have room for the card then its best that you buy IDE drive which 250GB or more.
thanks and good luck.
Ekse
SOURCE: xp could not find sata hard disk
the driver is not included in the driver cab on the xp and server 2003 disks, you will need to download the drivers and put them on a floppy disk (usb floppy if you do not have an internal drive) then as the blue setup screen is loading press F6 to load the drivers.
SOURCE: Sir my problem is that
Each PATA device (disk-drive or CD/DVD) drive has some small jumpers.
For the two devices connected via the one ribbon-cable,
set the jumpers on one device to the MA(ster) setting,
and set the other device to the SL(ave) setting.
Or, set both devices on the one cable to the C(able)S(elect) setting.
When properly set, both devices will be quickly and properly detected.
Be sure that your BIOS SETUP has been configured to allow SATA devices,
i.e., not set to "disabled" mode.
Ok, I'll reformulate the question.
I have a P4P800 motherboard in the pc and a SATA disk with Windows XP on it. A DVD drive (which is PATA) is connected with a PATA connector on the board.The system as such works fine. I want to add a second disk for data storage and that is a PATA. When I connect it the system does not startup in windows any more: it looks only on this data disk for the OS which is not there of course. I trid all possibilities: connect the data disk as slave on the cable which conneccts to the DVD (which itself is master): no way. I tried the second PATA connector on the board: no way. I tried other settings in the bios: SATA + PATA, PATA, etc. When I set it to PATA then the data disk is seen by the system and it starts windows normally, but... the DVD drive cannot read disks any more! I'm desparate!
