Question about Fossil Degrade Flame Animation JR8215 wristwatch
Fossil red degrade flame battery replacement
Which direction does the battery cover come off? and what tool should i use to get it off?
For this watch, the back screw off in a counter-clockwise direction. Put away the knife, and pick up the needle-nose pliers. See the 6 indents on the back of the watch? Push the pliers into the left side of the notch, forcing it in a counter-clockwise direction, and it should twist off.
Posted on Mar 20, 2008
Some watches, you screw off the backing. It rotates counter-clockwise, like a wood screw, but you need a special tool for it. It may have notches on the exterior, my watch has 6. I just used needle-nose pliers to twist it off, but this may and probably will cause scratches.
  • 328 Answers
Posted on Oct 28, 2007
How do i remove the back to replace the battery on this watch
Watch backs are usually either push-fit and simply need to be levered off, or are twist-fit and need to be rotated off. If there are a number of indentations around the rim of the back then it is likely to twist off. You need to get a suitable tool or tools to remove the cover or you will damage the back of the watch. Check on amazon or ebay for watch repair tools. Getting the cover back on is usually harder with push-fit and is more likely to lead to damage without the correct tools.
Or take it to a watch shop and they will replace the battery for you!
Jan 08, 2016 | Watches
How do you change battery
How to Change a Watch Battery with Normal Tools - YouTube
? 9:18
Sep 1, 2011 - Uploaded by RichsMethods
Hello, here's a video that provides straightforward, easy to follow steps on how to change a watch battery. I ...
Replace Your Watch Battery Yourself With Household Tools ...
? 7:32
Aug 15, 2013 - Uploaded by tsbrownie
How to replace a watch battery yourself using common household "tools". Covers both snap back and screw ...
How to Change a Watch Battery: 13 Steps (with Pictures ...
Dec 15, 2015 | Watches
How do I remove the back cover of a Fossil JR-8096 (Big Tic) wristwatch?
when you look at the back are there three small rectangular indents evenly spaced on the edge on the back? If so you'll need a special tool for opening waterproof watches. the tool adjusts to fit the three indents then press down as you turn counterclockwise. you can find the tool on or your local jewelry store. make sure the gasket is in place and not damaged before screwing the back on.
here is a link to the tool
Jul 31, 2012 | Fossil JR8096 Wrist Watch
How do i replace a 5.5 x 1.6 1.55 battery on a swatch
Swatch batteries should be replaced by removing battery cover on the back. If there is no such a cover, it can be done by taking out watch glass. The latter should be done by watch repairer, for it takes a lot of specialized tools and skill.
May 18, 2011 | Watches
How do you remove the rear cover to replace the battery on a rado ceramic mans watch ?there doesn't appear to be any access slot, where on many other watches a small grove allows a tool to be inserted...
the cover doesnt appears on the back side of the watch it is engraved with the main body of the watch,take it to a sevice centre they have tools through which the back cover gets separted with the main body of the watch
Feb 26, 2011 | Rado Maxi R21347712 wristwatch
Need to open. coleman 40-334 watch not sure if the back is threaded
mcdevito75 here, If the back screws down, you"ll see a series of square holes around the edge of the back cover, in this case you"ll need a special tool called a case back remover tool to un-screw the back cover. If there are no square holes on the back cover, most likely it"s a press type back cover and some of these cavers are very hard to get back on wothout another tool called a case back press tool, these mentioned tools are available on ebay, but, with just a battery replacement, the time and tools you may need the cost is more than a watch repair shop would charge you. Best Bet, look for a small watch repair shop in your area for this once a year or even longer battery change.
Feb 11, 2011 | Watches
How to remove the back of a watch to replacae the battery
mcdevito75 here, A special tool may be needed to press the back cover back onto your watch, no one can tell until the back cover is removed, this could be the case with your watch, if so, you"ll have a problem. BEST BET, look for a small watch repair shop in your area, the cost will be the same if you need this mentioned tool and anyway, the battery change is once a year or even longer
How do you get the back off a men's armitron watch to change the battery? Took it to Walmart and they can't figure it out.
If you don't have a watch repair kit, a small flathead screwdriver or even a butter knife would work. Set the watch face down on a soft material (pillow/towel). Insert the flat tool in the gap between the back and the watch itself. Apply a bit a of pressure the loosen and remove the back. Remove the rubber gasket covering the battery. Then you will want to remove the clip covering the battery (with the flat tool). Once the clip is removed flip it upside down and let the battery fall out
Nov 29, 2009 | Watches
Taking the battery out
some watches have a special way to open..nut by push/pull out the back but by rotating it .in this case it hase some small cuts in the back cover .if this so,it just might need to rotate.
Feb 02, 2008 | Kenneth Cole KC3289 Wrist Watch
Fossil Degrade Flame Animation JR8215 wristwatch Logo
296 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
