Our Refrigerator is 5 years old, it does not have an ice maker or water option in the freezer door. We noticed about 6-8 months ago that it would leak on the floor by the front corner of the freezer door. Never at the same time, not all the time. But it seems to be happening more and more.
Our frig is six years old and started leaking from the freezer side about a year ago,on and off,but now leaks constantly.The leak appears to originate from the back of the lower vent that throws off cold air into the lower part of freezer.The ice builds up pretty quickly on the bottom then melts as it nears the door, leaking onto the floor.
there is water in leaking into the bottom of the freezer as well as the freezer corner, in my case.
Solution #1
posted on Jan 28, 2008
Guest
Rank: Apprentice Rating: 0%, 0 votes
I vacuumed out the drain, after defrosting the freezer. And then, through a service contract, I had the defrost heater replaced. I'm not sure if it was one solution or both, but it seems fine now. Good luck, hope that info helped.
Was this solution helpful? Show your Appreciation by rating it:
Mine just starting leaking also. Water gathers in bottom, then freezessolid. then additional water leaks out. I've check ice maker and door water line. confirmed by turning off water supply. Water continues to build in bottom. I think it might be the defroster. somehow the defrosting water is not draining? Check your out and let me know what you find.
