Up until recently my computer has been able to play dvds fine in my LG GDR 8163BB Combi but recently there is a distortion in the sound when i play a dvd. Playing movie files saved on my hard drive its just when its from a dvd any ideas what could be causing the problem?? Kim
Comments:
Oct 28, 2007
- Unfortunately that didnt work still distorted. Thanks tho.
Oct 28, 2007
- I understand what your saying but im not really 100% sure how to go about doing what you've said. I also tried looking for the drivers to update them but cannot find them anywhere for the drive.
Oct 28, 2007
- Ok so if thats the case what do you think i should tackle next? Sorry to be a pain but this sort of area i have no clue in.
Go into your Control Panel by first clicking on the Start Button.
Then click on Settings and then click on the Control Panel icon.
Locate the System icon and Double click on it to open up the System Properties window.
Then click on the Device Manager tab at the top of the screen.
Now click on the plus sign [+] next to the CD ROM Icon to expand that section.
Double click on your CD Rom Drive to display the Properties Window.
Then click on the Settings tab at the top of the screen.
Within the Options section, You will see a white box next to DMA.
Placing a check mark into this white box will enable the high speed DMA transfer setting.
Clearing an existing check mark from this white box will disable the DMA transfer setting.
Then click on the OK button at the bottom of the screen to save your settings.
And then click on OK to exit the System Properties Window.
Select Yes when Windows Prompts you to Restart your Computer now.
Repeat the above procedure on any additional CD/DVD Rom Drives you have in your system.
Oct 28, 2007
For Windows XP
Then click on the Control Panel icon located in the right column of the Start Menu.
If your Start Menu is set to the Classic View, then begin by clicking on the Start Button.
Then click on Settings, then click on the Control Panel icon to open up the Control Panel.
Now, Double click on the System icon to open up the System Properties window.
Now click on the Hardware tab located at the top of the screen.
Then click on the Device Manager button in the center area of the screen.
Now click on the plus sign [+] next to the IDE ATA/ATAPI controllers to expand that section.
Then double click on the Primary IDE Channel to display the Primary IDE Properties window.
Then click on the Advanced Settings Tab at the top of the screen.
Now for Device 0, ensure that the Transfer Mode: selection is set to DMA if available.
Then for Device 1, ensure that the Transfer Mode: selection is also set to DMA if available.
Then double click on the Secondary IDE Channel to display the Secondary IDE Properties window.
Then close Device Manager and the Control Panel to return back to your Windows session.
Oct 28, 2007
- if you are using power DVD
See if in the options/advanced options of PowerDVD if there are any checkboxes for hardware video or audio acceleration. These can make the difference between smooth playback or stuttering/glitching audio.
I'd also make sure your video drivers are current, AGP is working properly (if an AGP video card) and you have the latest video drivers. In most cases, stuttering sound is due to the inability to sync audio since there isn't enough CPU resources to do this after video decode. If you can somehow reduce CPU load, this will usually clean-up audio problems.
Low memory conditions, trojans, spyware or incorrectly configured/too many systray applications can also do this. I'd try disabling any extra systray tools/utilities and messengers as well to make sure these aren't messing up dvd playback. The Task Manager should also be helpful for sorting by CPU utilization to see what might be taking up unnecessary CPU time, as well as inspecting how much available memory is free on your system prior to launching your DVD application.
Oct 28, 2007
- windows has its own drivers installed already
for the cd and dvd drives.
Oct 29, 2007
- In most cases, stuttering sound is due to the inability to sync audio since there isn't enough CPU resources to do this after video decode. If you can somehow reduce CPU load, this will usually clean-up audio problems.
Shut off things you dont need during the playback of your DVD
did you install any new programs from when it worked good to now?
Oct 30, 2007
- if none of these solutions work,and if it is not under warranty, I would replace it.
Oct 30, 2007
- please rerate this problem.
Nov 06, 2007
- Did this work? Please post an answer so we can help you further. If it worked please rate this post as solved. Thanks,
lg dvd writer with securDisc cant copy from cd or dvd, i hav a p4 with 512RAM on windows service...
(More)
lg dvd writer with securDisc cant copy from cd or dvd, i hav a p4 with 512RAM on windows service pack2. the discs are opening ok, but cant copy or play music.
install LG dvd drive..... lost the installation cd..... can i find some thing free on net to...
(More)
install LG dvd drive..... lost the installation cd..... can i find some thing free on net to install
I have a new install system with the following configuration - MOBO - M2N68-AM Processor - AMD...
(More)
I have a new install system with the following configuration - MOBO - M2N68-AM Processor - AMD Athlon 64 x2 dual core 6000+ HDD - SATA1 Vendor WD 320Gig Memory - 2Gig DVD/RW - LG 20x (GH20) SATPI When I try to install Vista 64 it is very slow and after about 2 hours it says that the driver for the DVD needs to be updated. This is the 2nd drive that I've tried and the 1st drive had the same response. Things I've tried - Updated the BIOS Changed the SATA cables reset the CMOS changed DVD drives (the 1st one was a Sony DVD) downloaded all of the MOBO drivers, but they are not accepted Suggestions? Dan
LG CD drive doesnot have the same cable connecting to motherboard. My current cable is much wider...
(More)
LG CD drive doesnot have the same cable connecting to motherboard. My current cable is much wider than the newly purchased CD drive. Thanks Ken
