SOURCE: Not only is my asko washing machine leaking, the
F3 is a blocked drain...open coin trap remove blockage... also in the trap door is a red release string.. remove screw and pull it will release the door...
Hope it helps if NOT let me know more about your problem... and I will help
SOURCE: washing machine wont drain, door is locked, and
sounds like a safety check is on. check the pump to make sure nothing is stuck in there. read the manual for checking pump on that Asko machine..
SOURCE: my machine wont drain and the door wont open. I
Make sure that you have power to you machine by plugging a light into the wall oulet. If there isn't any power, go to your circuit breaker box and look for the breaker that supplies that oulet. If everything is good there, it probably is going to be a service charge to get someone to look at the unit since it is more complicated than you want to get into.
