HI Patricia,
I suggest You Go to Official Canon Printer Page For You Canon Printer Problem On Below Canon URL Link: PIXMA MP282 In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
SOURCE: Black line prints on back of paper
I have the same problem and I have not found any fix yet.
SOURCE: printer door open message
Further to this, the sensors can give way. Try soldering or pushing the two connections together. If you need to test, you will have to put the lid back on but you can leave the sensor out of the rinter by draping between the cover and the frame of the putput tray (be careful not to pinch it. AAMOF I leave my sensor out as even though I've pinched it together it has a habit of coming undone.
SOURCE: Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn /
3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn
/ 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's
operator panel, perform the following steps:
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure
1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator
Panel
To verify the paper type matches the type set in the printer's operator
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the
MPF only.
Verify the printing preferences on the Dell™
3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with
the correct paper size, perform the following steps:
The Printers and Faxes
window appears.
The
Printing Preferences window appears.
This sets the size and tray
defaults.
Verify the Paper Size From the Printing Application Matches the Designated
Printer Tray
To verify the paper size from the printing application matches the designated
printer tray, perform the following steps:
Verify the Paper Source From the Printing Application Matches the Designated
Printer Tray
Do not replace any printer hardware as this is not a printer hardware
issue.
SOURCE: paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
tuval.
[email protected]
hope fore replay.... :)
