Question about Dell W3201C 32 in. LCD Television
Re above Screen went off and although unit continues to run and blue on off light is picture.
Re: re above
I have the same problem on my 32 in,after having the Tv on for about 3 hours Tv turns off, every 10-20 min. tv turns off. very upset with DELL. , blue light stays on.... what can i do to fix promblem.......
Posted on Dec 07, 2007
0 characters
3 Points
I have Vizio I changed cable from Dish Network to a Local Co. now I can't get cable or sound, although the cable box is all lit up. I get a blue screen with no signal running across it and I have
check with whoever is your current signal provider---paying for service they will usually come out and make sure it is working either via the coax fitting or via the audio/video jacks
May 17, 2012 | Vizio Flat Panel Televisions
TV was working fine till Friday 29 Jan 11. Went to turn it on screen was dark blue,but sound was on, after about 10min the screen went to bright blue then the picture came on. Saturday the same thing,...
The problem you are having is the power supply in the TV is failing. When you try to power the unit on you get on power or a slow turn on. It also can explain the problem of not running at full 1080p resolution because the higher the resolution the no power is required to operate the TV. Check out the article that explains the problem and how to repair it.
I hope this helps, if so please rate our solution.
Jan 30, 2011 | Element Electronics FLX3711B 37 in. LCD TV
I turn the tv onblue light lights up (meaning power tv turn on) but nothing shows up on the screen. Was working fine one night and the next morning didnt work
Remove the power from the unit for a minute. Plug in and see if it works. If it does great if not continue.
There is a possibility that the LCD Lamp blew. To check this, turn the unit on. Look really close at it for a picture. The picture will be dark adn hard to see from a distance but it would be there if there is no damage to the main components. If there is a picture than either the lamp or inverter went, you will need to have it serviced or replace the unit.
If there is no picture at all then your unit may have had the tuner board go in it. This is a service only option. Best thing to do is take this to a tech shop.
Jun 13, 2010 | Flat Panel Televisions
Blue Light comes on but no picture
Hi, do you still have sound. Can you control your volume. It might be one of your sustainer boards. Please let me know. It could be your SDR boards too.
May 14, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Image goes to black on Sharp flatscreen.
An LCD unit? Sounds like the backlight is failing. When it goes black next time, use a strong light next to the screen and look for a faint image on the screen....
If it is the backlight, its a service shop issue.
Mar 23, 2010 | Sharp 19 in. LCD HDTV
No picture akai 42 inch plasma
I have not solved problem, although I paid you to solve it many months ago. The information I paid for was not the problem although the answer I was given was someone telling me it was for sure the problem.
Oct 03, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Aug 08, 2009 | Sony KDF-42WE655 Television
Volume works but picture will continuously blink
You control module is defective there is an exchange policy but it is very expensive. If you can send me the model number and serial number i will check to see if it availabel and what the cost will be.
Lou Margo
Allied Electronics
513 490 0759
Nov 25, 2007 | Polaroid FLM-2601 Television
Dell W3201C 32 in. LCD Television Logo
121 people viewed this question
Top Dell Flat Panel Televisions Experts
Jaime Hernandez
Are you a Dell Flat Panel Television Expert? Answer questions, earn points and help others
