i have 3 acer al1603w widescreen monitor.. it was working ok before, then i let my brothers used them. afterwhich it is displaying "input not supported". WHOAAA!?!!? what do i do? its bugging me for 3 days now, when i try to boot in cdrom there is no display. Same thing when i press f8. Resolution when i check on monitor menu is 800x600. Help please.. TIA.
hi,I had same kind of problem I was using CRT monitor with xp OS and due to some problem i thought to change it to LCD so i bought this acer monitor and start working with it later some days i planed to upgrade my system so when i was reinstalling OS i got the message input not supported so I checked with vendor carrying my monitor the reason for this problem is, model does not support dos mode so i connected with CRT monitor and reinstalled OS and set the settings to 1024 to 768 and reconnected with LCD it started working.try this it worked for me
Sounds like somebody messed with the monitor setup on the monitor controls. Check the manual to set it up correctly. If they changed the monitor's Frequency settings, the problems you are having will occur. Gotta set them back to 70Hz and check the other settings. If you need a manual, get back to me with the exact model number of the monitor.
Was this helpful?
Yes
No
Popular Solutions for Acer AL1916W 19" LCD Monitor
I've changed all the setting to Extra Large and nothing happens the fonts are still small in all my...
(More)
I've changed all the setting to Extra Large and nothing happens the fonts are still small in all my program, Simply Accouting and such
My banners for Facebook and some other things are not displaying correctly on my administrator login...
(More)
My banners for Facebook and some other things are not displaying correctly on my administrator login but are fine on the guest login. help.
