Question about Frigidaire 14 Cycle Tumble Action Washer
Frigidaire Model GLTF1670AS0
Washer fills but will not drain???? Drains when hose is flat on ground
SOURCE:
  • 1314 Answers
SOURCE: Frigidaire washer machine #FWTBB30DS0
check to see if your drain hose is too far down in the stand pipe this will siphon water out as it fills.
Posted on Jan 17, 2008
  • 3 Answers
SOURCE: frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Posted on Jul 28, 2008
  • 196 Answers
SOURCE: Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Posted on Nov 12, 2008
onthejob5130
  • 640 Answers
SOURCE: Frigidaire Washing Machine Model # GLTF1670AS0
back bearings defective,,,should sound like train coming down on track..
Posted on Dec 29, 2008
michiganfan9
  • 179 Answers
SOURCE: Frigidaire Washing Machine Model # GLTF1670AS0 Makes very loud
if the noise is really loud in the final spin your bearing are starting to go out your washer needs to be rebuilt but it will be cheaper to go buy a new one
Washer doesnt fill , instead it drains as its supposed to be filling
check that your stand pipe is 36 in high of the ground and that you have a air gap from your outlet hose and keep the hose at that hight
Nov 28, 2011 | Washing Machines
My GE washer drains as it is filling but the spin cycle works fine why?The washer model # is wcsr2080b4ww thanks
The standpipe that the drain hose drains into is too low. Make sure your drain hose is at least 36 " high.
Oct 10, 2010 | General Electric WCSR2090G Top Load Washer
Washer drains then spins then fills again and drains but no spin
Try this, unplug washer for two minutes, plug back in, open and close lid seven times slowly, this will reset the computer and the electronic motor. Also on water level switch, make sure hose from switch to tub is not plugged, blow it out, gets clogged with soap.
Sep 09, 2009 | GE WBSR3140DW Top Load Washer
Water fills to normal level, then drains (not on the floor).
You need to raise your drain hose a minimum of 30". Check this out and hope it helped. Best wishes.
Jul 27, 2009 | Kenmore 22422 Top Load Washer
Fills and Drain...
Check your washer drain line for a possible siphoning condition. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Read through the link I provided. Your problem may be a simple matter of drain hose placement. If this does not solve your problem, please post back and let me know. I hope this helps you.
Jun 22, 2009 | Kenmore 98702 Stacked Washer/Dryer
Water just drains, wont fill up washer
the top of the hose must be higher than the water level in the washer for proper operation
or
the drain house should be loose yet fit securely. do not seal the drain hose with tape the hoese needs and air gap
Apr 17, 2009 | Washing Machines
Washer fills and drains at the same time. doesn't change cycles
check the washer drain hose, it is probably sipening the water back out, try pulling it out of the drain a few inches
Apr 07, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool washer fills, begins to agitate, then drains
Water siphoning out the drain line
If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
moz-screenshot.jpgThe washer fills and drains at the same time only on the rinse cycle.
Shut the machine off with timer during this period and raise the drain hose. If the water continues to drain, you will need to install an anti-siphon kit.
Please leave a solved rating before you sign out
Jan 31, 2009 | Whirlpool LBR4121JQ Top Load Washer
Washer fills and drains repeatedly
Have a look at the routing of your drain hose. It sounds a bit as if: a. The highest point of the hose isn't high enough (you normally want to aim for about 3 feet off the ground) - so that water starts draining from the machine before it is finished filling. and b. There isn't an effective air break or anti-siphon valve where the drain hose goes into the domestic drainage system - so that once the machine starts to drain by itself, it continues until empty. A.
Jun 07, 2007 | GE WJSR2070B Top Load Washer
Washer fills then drains
Daisy, check your drain hose going into the drain. It sounds like you have a siphoning problem. If the drain hose does not have a air gap the water filling will siphon right out. Check this first and post back, Catriver.
Sep 21, 2006 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire 14 Cycle Tumble Action Washer Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
