Computer, Chip, Cruise Control for Honda Accord Crosstour Logo
A
Anonymous Posted on Feb 26, 2014
Adjusting power seats
When I test drove this used honda when the ignition was shut off the power seat would automatically lower and move back for easy exiting. It no longer does that. Can these vehicles be ordered with this option or is that a after market add on?
George Dubbs
Level 2:
Sergeant:
  • Expert 406 Answers
  • Posted on Oct 03, 2014
George Dubbs
Expert
Level 2:
Sergeant:
Answers
406
Questions
Helped
134351
Points
928
That is an option that can, is set to fit the drive/ drivers needs of the vehicle..ThIs can be reset.you will need the owners manual to do this..sometimes if the battery goes dead or disconnected options like this need resetting..not an aftermarket that I have heard of..good luck.
1helpful
D110 won’t start got fire won’t even click , like some safety switch is not disengaging
Starting instructions per manual.
  1. Make sure bypass rod is pushed in.
  2. Sit in seat.
  3. Make sure mower is disengaged. (See Engaging and Disengaging Mower in the OPERATING section.)
  4. Lock the park brake.
  5. For automatic models, put transmission shifter into center slot.
  6. Parking brake - ON
If it still doesn't crank, cycle the safetys.
  1. Parking brake - OFF/ON
  2. PTO - ON/OFF
  3. For automatic models, move shifter out of center slot then back.
  4. Seat switch - Rise from seat then sit firmly.
If still no crank, check battery charge is at least12.5VDC. If battery ok, then likely a safety switch has failed or misaligned. Try rotate and hold ignition switch at start position and see if moving safeties allows crank. Move out/in seat, pull PTO switch on push off, move brake to off then back on. Other possible causes include fuse, ignition switch, relay, poor circuit continuity (power, control, or ground).
Apr 27, 2019 • Garden
2006 LINCOLN ZEPHYR DRIVERS ELECTRIC SEAT WILL NOT MOVE BACK WHEN KEY IS TURNED OFF
Principles of Operation
The driver seat module (DSM) is on the controller area network (CAN) communication network. To support several vehicle subsystems, the module permits intermodule and diagnostic tool communications.
The DSM controls the memory driver seat and the passenger memory power exterior mirror. This passenger memory power exterior mirror feature allows the driver to program personalized mirror positions. Once the driver stores a mirror position, the driver can recall the setting by pressing the corresponding memory switch or by using a programmed remote keyless entry (RKE) transmitter. For additional information, refer to Section 501-10 .
How to Diagnose Controller Area Network CAN
Driver Seat Module - Memory Seat
The power driver seat, power outside rear view mirrors and power adjustable pedals are controlled by the driver seat module (DSM) only when the vehicle is equipped with the programmable/recall memory option. The DSM is located on the driver seat track.
This system allows automatic positioning of the driver seat to 2 programmable positions.
  • A power driver seat position can be stored at any time. The driver must move the seat to the desired position using the driver seat switch assembly. The driver must then depress the memory SET switch which activates the memory SET switch light emitting diode (LED). Within 5 seconds (before the LED goes out), the driver must select a memory position. Memory 1 is selected by depressing memory switch 1. Memory 2 is selected by depressing memory switch 2.
  • If no memory switch input is received within the 5-second time limit, the operation is aborted and the memory seat position switch (set switch) LED is turned OFF. This also occurs if one of the following inputs is received during the 5-second programming limit:
    • Driver seat control switch
    • Memory seat position switch (set switch)
    • Power adjustable pedal switch
A programmed seat position can only be recalled when the transmission selector is in PARK or NEUTRAL with the ignition switch in the RUN position. A position may be programmed at any time.
Easy Entry/Easy Exit
The driver power seat easy entry/easy exit feature can be enabled/disabled. Refer to Section 418-01 or the owner's literature.
This may need to be done with a scan tool
2helpful
The driver's side heated seat won't turn off on my 2003 Mecury Moutaineer. Also, how do I change my cabin filter?
Your vhicle build date is on a blue sticker on the driver door or door frame. If not there, check other doors.
The heated seat Module is under the seat. You can unplug the connector on it or the heated seat switch to shut it off. I supect the module is bad. get one used from car-parts.com. The cabin air filter is under the leaf screen at the base of the windshield. Remove wiper arms and leaf screen for access. Please rate, thanks. Principles of Operation - Heated Seats - Vehicles Built 03/2002 Onward
NOTE: Two heated seat modules are used, one for vehicles built up to 03/2002 and one for vehicles built 03/2002 onward. The modules are not interchangeable.
The driver and passenger heated seats share a common battery and ignition feed. A shared ground source supplies the heated seat control switches. When the heated seat control switch is pressed with the ignition switch in RUN or START, a momentary ground signal is sent to the heated seat module. The heated seat module then supplies power to the heating element circuit. The cushion element and seat backrest element are wired in series and powered by the same output. The heated seat module also will ground the separate indicator circuit at the dual automatic temperature control (DATC) module display panel to indicate an ON state. The heated seat module will remain on until the heated seat control switch is pressed and a momentary voltage signal is received, or until 10 minutes expire. If the ignition source is removed from the module, the heated seat module will enter an OFF state and will not return to ON until the switch is once again pressed with the ignition switch in RUN. The heated seat module is designed to heat the seat to 37.5?C (99.5?F) and maintain the temperature until time-out or switched off. This temperature is maintained by the heated seat module monitoring the temperature sensor located in the seat cushion element, and adjusting the current flow to the heating elements.
How to move forward the Driver's seat of the 2000 Honda Odyssey Driver's seat
the knob on the left side of the lower cushion if its power seats push it forward, if not power pull the lever under the front of the cushoin UP to move the seat
1helpful
Automatic Seat Belt. in Honda Accord 91 EX
check fuses or see if something might have got jamed in the track and also try movin the part where the seat belt moves back and forth to see if the motor is dying
1helpful
2answers
1998 Honda Accord automatic seat broken. replacement?
the electric motor for forward and back is bad salvage yard easy to change let me know hey vote for me ok
1helpful
Driver's power seat not working properly on 2004 tahoe
it sound like you need to replace seat control switch
1helpful
2answers
Power seat won't recline
My 2006 honda accord drivers seat makes a clicking and grinding noise when i try to put it in the recline position.It will go back about halfway and stop and make this noise, does anyone have a suggestion?
1helpful
2001 Lincoln LS Easy Entry power seat function
may need dealer to reclaibrate using his tool.
Driver Power Seat The driver power seat is controlled by the driver seat module (DSM). The DSM does not need to be configured, however the drive seat does need to be calibrated when the DSM is installed. The driver seat regulator control switch provides voltage to the DSM when activated. The neutral position of each driver seat regulator control switch position is a ground state through the seat regulator control switch contacts. A voltage input causes the DSM to power the appropriate motor until the input is removed. Ground is the normal state of the motor circuits through the DSM and is not switched to control the motors. The DSM internally switches the appropriate line from ground to power to adjust the motors.
As the seat is adjusted, the DSM constantly monitors the motor position sensors to record the current seat position. The DSM will remove power from the motor upon termination of the seat regulator control switch input or if the DSM does not see movement from the motor by monitoring the position sensor. The DSM must be calibrated to the seat track it is controlling. For additional information, refer to Seat Calibration. Once the DSM is calibrated to the seat track, it will only allow movement within the calibrated range.
Seat Calibration The DSM is calibrated using a scan tool. The calibration procedure automatically powers the driver power seat through its full range of motion and records the full stop positions by monitoring the motor position sensors. Once the full stop positions or range of the seat have been recorded, the DSM will only operate within the calibrated range. Any input attempting to drive the seat beyond the calibrated range will be ignored. This calibration is used for all seat control functions including manual switch control and memory recall positioning. During the seat calibration, the DSM may identify a function that is inoperative, such as a position sensor not changing. If the DSM identifies a concern that has a related diagnostic trouble code (DTC), the DSM will set the related DTC at the end of the validation procedure.
The calibration procedure powers the seat track adjustments to the end of their travel, which is determined by the DSM seeing a change of state in the motor position sensors. If there is a concern with the seat track or motor position sensor that limits the travel, the DSM will interpret the stopping point as the end of travel and store the position. The DSM is not able to determine if the seat has moved to its full travel position. It is only capable of monitoring and storing the amount of travel seen by the position sensor changing states.
For additional information on carrying out the power seat calibration procedure, refer to the scan tool operating manual.
Memory Seat Memory seat positioning can be recalled with the memory switches on the driver door panel or a programmed remote keyless entry transmitter. In either case, the DSM receives a memory recall 1 or 2 command from the driver door module (DDM) over the SCP communication network. The memory recall switches are a hardwired input to the DDM. The DDM also receives the remote keyless entry transmitter signals. Once a valid memory recall command is received from the DDM, the DSM moves the drivers seat to the position stored in memory by powering the appropriate motors and monitoring the motor position sensors until the position is reached.
Easy Exit/Easy Entry The easy exit function moves the seat backwards about two inches when the ignition key is removed from the ignition switch. The DSM receives a key out command over the SCP communication network and powers the driver seat rearward. This function will not operate if the seat is less than the travel distance to the end of the track, or the function has been deactivated at the message center driver personality settings. The DSM will also cancel this operation if a valid input command is received, such as the seat regulator control switch or memory recall request.
The DSM will record the current seat position before powering the seat for a easy exit function. This recorded position will be used to return the seat to this position on the easy entry operation. During easy entry operation, the seat is returned to the position previous to the easy exit operation. Easy entry operation will be cancelled if a valid input command is received by the DSM.
Passenger Power Seat The passenger power seat motors are hardwired to the passenger seat regulator control switch. The circuits are normally at ground through the seat regulator control switch. The individual circuit is switched to power when the specific adjustment position is selected.
Heated Seats The driver and passenger heated seats share a common battery and ignition feed. A separate shared ignition source supplies the heated seat switches. When the heated seat switch is pressed with the ignition switch in RUN, a momentary voltage signal is sent to the heated seat module. The heated seat module then supplies power to the heating element circuit. The cushion element and seat backrest element are wired in series and powered by the same output. The heated seat module also will ground the separate indicator circuit at the heated seat switch to indicate an ON state. The heated seat module will remain on until the heated seat switch is pressed and a momentary voltage signal is received, or until 10 minutes expire. If the ignition source is removed from the module, the heated seat module will enter an off state and will not return to ON until the switch is once again pressed with the ignition switch in RUN. The heated seat module is designed to heat the seat to 37.5°C (99.5°F) and maintain the temperature until time-out or switched off. This temperature is maintained by the heated seat module monitoring the temperature sensor located in the seat cushion element, and adjusting the current flow to the heating elements.
Inspection and Verification
  1. Verify the customer concern by operating the system.
  1. Visually inspect for obvious signs of mechanical or electrical damage.
    Visual Inspection Chart Mechanical Electrical
    • Front seat track motors.
    • Front seat track binding or obstructed.
    • Front seat backrest power recline.
    • Lumbar motor.
    • BJB Fuses 411 (15A), 421 (20A), 425 (40A), 428 (20A)
    • CJB Fuses 205 (5A), 216 (5A), 207 (5A)
    • Seat regulator control switch.
    • Memory set switch.
    • Lumbar seat control switch.
2helpful
2001 Lincoln LS. Selecting seat/mirror/steering wheel positions works for all except the driver seat. Could this be a fuse/breaker problem? If so, where are they? Is there other possible cause for this?
you may need to have the dealer calibrate the seat with his diagnostic tool. I would guess ariund 1 hr labor time.
info:
    • Lumbar motor.
Top Honda Vehicle Parts & Accessories Experts
john h
Arnie Burke
Arnie Burke
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
