Panasonic Lumix DMC-FZ70 16 Megapixel Digital Camera, 20-1200mm 60x Optical Zoom Lens, Full HD Recording, RAW files, Dolby Digital Sound Logo
A
Anonymous Posted on Feb 26, 2014
Dropped panasonic lumic fz 70 - Panasonic Lumix DMC-FZ70 16 Megapixel Digital Camera, 20-1200mm 60x Optical Zoom Lens, Full HD Recording, RAW files, Dolby Digital Sound
How do I get rid of Sepia setting in my panasonic DMC-FZ-70 camera?
I DON'T KNOW. IF AVAILABLE, CONSIDER 'RETURN TO FACTORY SETTINGS' OR 'ORIGINAL SETTINGS'.
Mar 19, 2019 • Cameras
I have just purchased a Lumic Panasonic camera DMC-FS10. Could you please tell me what memory card is the best to purchase for this model. Thank you
Your camera can use both SD and SDHC (high-capacity) cards. With 14 megapixels, I'd recommend the SDHC. If you're going to shoot videos, get a class 6 card. It's more expensive but it shoots videos trouble-free. Sandisk is a good brand.
How do i format the memory card in a fz 38camera
Go into the menu and scroll to "format" and follow the on-screen instructions.
Nov 13, 2009 • Cameras
DMC FZ 20 powers on but the controls do not work.
Make sure the camera is not in play mode. look for a reset procedure or a firmware flash procedure.
2helpful
Please Turn Your Camera Off and Then On Again?
THIS MESSAGE APPEARS WHEN A FAULT HAS GONE WRONG WITH THE LENS. EITHER CAMERA HAS TAKEN A DROP OR KNOCK. THIS CAN BE REPAIRED BUT NEEDS TO GO TO A PANASONIC SERVICE CENTRE.
"DMC" and "FZ"
DMC Digital Microcircuit, Dynamic Motion Control
Low light situation
Where the Panasonic FZ-20 does very well, is with conditions where you need a long zoom under low light. Most lenses will lose light as they are zoomed out. The Leica lens in the FZ-20 does not lose light when zoomed. No matter which camera you are using, you will have to use the manual controls for the best results. So learning about exposure and how to use it, is necessary.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
