Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Samsung remote control acces
How do i get the the access program on my remote to fix a possible convergence problem
  • Dixon481 Nov 12, 2007
    I was having the same issue. I thought my TV was done for. This solution helped me fix it. THANK YOU!
  • mrmark Dec 26, 2007
    i dont have the original remote and im having issues lining up the blue green and red convergance lines im close but with my universal remote i may be missing some functions can anyone help thanks
Key Functions
7,8,9 = select R, G or B
+100,0,PRE-CH = mute R, G or B
INFO = test/normal
4 = shifts from point to line, grid move
2 = restore factory
SOURCE = H/V select
ADD/DEL = Save
S.MODE = exit
MUTE = cursor forward
P.MODE = cursor back
Volume +/- = moves convergence left or right
Channel +/- = moves convergence up or down
1 = zero's all convergence settings (ugly!)
U/D/L/R = move cursor
SELF FOCUS = saves the convergence adjustment - do before exiting
Posted on Oct 29, 2007
  • joeee Oct 29, 2007
    Forgot, 1st it's mute-1-8-3 to gain access than it's
    INFO = test/normal
    2 = restore factory
    SOURCE = H/V select
    ADD/DEL = Save
    S.MODE = exit
You guys ROCK! The auto Focus was blurring the right side of the screnn... I found this site and used your solution and now it is crisp and clear!!!
THanks!
--JW
Posted on Dec 08, 2007
How to program New key switch 2000 oldsmobile silhouette
Key switch ? key fob ? Transmitter Programming ?
If you lose a transmitter, program the old and new transmitter(s) into the remote control door lock receiver's memory. Up to 4 transmitters may be programmed.
Important: Once the remote control door lock receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information, requiring the programming of all transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If more than 1 receiver is being programmed at the same time, it is possible that the same transmitter could be programmed to more than 1 remote control door lock receiver.
Perform the following steps in order to program the transmitter:
  1. Remove the ignition key from the ignition lock cylinder.
  2. Remove the BCM PRGRM fuse from the fuse panel. Refer to Fuse Block in Wiring Systems.
  3. Close all of the doors.
  4. Close the lift gate.
  5. Turn the ignition lock cylinder to ACC.
  6. Turn the ignition lock cylinder to OFF, and then back to ACC within 1 second.
  7. Open and close any vehicle door.
  8. A chime will be heard when the system enters the BCM programming/diagnostic mode.
    Important: After 7 seconds, a chime may be heard confirming successful synchronization. It is necessary to wait approximately 14 seconds for a second chime that will confirm successful programming.
  9. Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds.
  10. Repeat the previous step on each additional transmitter to be programmed.
  11. Remove the ignition key from the ignition lock cylinder.
  12. Install the BCM PRGRM fuse back into the fuse panel. Refer to Fuse Block in Wiring Systems.
Apr 22, 2016 | Oldsmobile Cars & Trucks
Alreaddy did replace new batteries for key remote but the key remote is not working properly.. What cause is that?? do you know??
I know that this procedure work for Grand Prix and Monte Carlo, tesi it...
KEY FOB PROGRAMMING INSTRUCTIONS
No Tools Required
In the event that a transmitter is lost, program the old and the new transmitters into the memory of the remote control door lock receiver. Up to 4 transmitters may be programmed.
Important
Once the keyless entry receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If you program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver.
Perform the following steps:
Sit in the vehicle driver's seat. (actually it’s much ezr from the front pass seat)
Close all of the vehicle's doors.
Remove the MALL PGM fuse from the fuse panel. Refer to Electronic Diagnosis in Body and Chassis.
Turn the ignition lock cylinder to the ACC position.
Turn the ignition lock cylinder OFF, then back to ACC within 1 second.
Open and then close any vehicle door. You will hear a chime when the remote control door lock receiver enters the programming/diagnostic mode. If you do not hear a chime, start again at step 1.
Important
After 7 seconds, you may hear a chime confirming successful synchronization. After approximately 14 seconds, you will hear a chime confirming successful programming.
Repeat step 8 in order to program each additional transmitter.
Hope helps.
Jul 16, 2010 | 2001 Pontiac Grand Am SE
Tv-remote
RCA RCR311B Remote
Jun 28, 2008 | RCA ACC-RCAURC Remote Control
Red is out of convergence
I would stay away from that repair man. That model has just one Convergence IC number STK393-110 and it takes about 45 minutes from start to finish to remove the old IC and install the new one. You can get the replacement IC at the following link and they provide free instalation instructions with pictures so you can do the repair yourself for less than 30.00. Heres the link. You need just 1 STK393-110 Convergence IC they have free shipping as well.
http://servicemanuals.vstore.ca/
Jun 19, 2008 | Toshiba 42H81 42" Rear Projection...
Rear Projection Samsung w/ convergence out
I believe it is mute-1-8-3 to enter the service mode, HOWEVER, I have also read that until the convergence problem is repaired, i.e. - depending on the configuration, either 2 individual IC's located on the lower board with 'playing card' size heat sinks or a simple replacmenet convergence board, adjusting the convergence through the service mode is comparable to "ripping the transmission out of your car to fix a flat tire". I myself have not gone into the service mode since I am still waiting for the replacement IC's - I get to do a component level repair.
May 05, 2008 | Samsung PCL545R 54" Rear Projection...
Where can i buy remote control for phillips 55pp9401?
get a full universal at your local walmart for less then 20 with full menu and program functions, get a phillips brand and no programming required.
Mar 16, 2008 | Philips 55PP9401 55" Rear Projection...
Fine tuning grid on my Samsung HDTV with remote.(BP59-00048)
To adjust manual convergence on your projection TV, follow theses steps:
  1. Turn your TV on.
  2. Let it warm up for 30 minutes.
  3. Press the Menu button on your remote. The Main menu appears.
  4. Use your remote to select Function, and then press the joystick.
  5. Select Convergence, and then press the joystick. The Manual Convergence screen appears.
  6. Select Red, and then press the joystick. A series of crosshairs appears on the screen.
  7. Select one of the outside crosshairs by moving the joystick up/down/right/left or by pressing the 2 (up), 4 (left), 6 (right), or 8 (down) buttons on your remote. The method you use depends on the model of remote you have. Note: You must do the outside crosshairs first.
  1. In the crosshair you selected, if you can see a horizontal red line, use the CH up or CH down buttons to move the line so that it is superimposed on the horizontal center line of the crosshair. Note: Make the single horizontal line as white as possible.
  1. In the crosshair you selected, if you can see a vertical red line, use the Vol + or Vol - buttons to move the line so that it is superimposed on the vertical center line of the crosshair. Note: Make the single vertical line as white as possible.
  1. Repeat for all outside crosshairs, and then for the inside crosshair.
  2. Return to the Manual Convergence Screen, and select Blue, and then press the joystick.
  3. Repeat Steps 7 through 10 for Blue.
  4. Press the Menu button on your remote to exit.
Important: The directions above work for most Samsung Rear Projection TVs. Yours may be different. For exact directions to perform manual convergence, see your user's manual. If you don't have your user's manual on hand, click HERE to view your manual on line.
If you cannot get your Projection TV to converge, it may need to be serviced. To arrange a service appointment, call Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your TV's model number and serial number on hand when you call.
Jan 05, 2008 | Samsung BP59-00016A Remote Control
Red convergence way off
I had the same issue as you pretty much exactly and so do others right around this last few weeks so I am thinking that this is a common problem with the product itself.
You can fix this pretty quickly with the link below. I bought it and it resolved the issue.
http://www.partstore.com/Part/Samsung/Samsung/PCN5425R/Samsung/Samsung/BP9500142E/New.aspx
Jan 02, 2008 | Samsung PCN5425R 54" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
527 people viewed this question
Jerry Greenberg
Jerry Greenberg
