Question about Whirlpool Duet GHW9150P Front Load Washer
Broken door open washer door o get the my close and door wont close
  • 64 Answers
Before you replace the door catch, try a squirt of WD40 through the hole where the door striker fits, it might be stuck!TURN POWER OFF FIRST!
Posted on Oct 29, 2007
    Problem Solver:
  • 10 Answers
You probably have to bad door latch. its easy to replace. it requires i believe a number 20 torx bit you have have to remove the spring around the door boot and then you can put you hands to inside the unit to remove the latch.
Posted on Oct 28, 2007
My maytag commercial washer display a code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
Washer wont spin
see this possibles cause:
It doesn't pump or spin
frozen pump pulley+drive pump belt broken replace
It pumps, but doesn't spin
lid switch open, or defective +motor coupler broken+belt broken+clutch worn+motor defective.+transmission not shifting properly+basket worn
It spins only with the lid closed
safety the machine will run with the lid door closed.
God bless you
Jun 28, 2012 | LG WM1814CW Front Load Washer
My washer panel will light up and the load washer light will come on, but the machine won't start
To me that sounds like the problem may be within the door switch/lock, on the doorlock asm. is a little botton that sticks out of it,look and see if its their or perhaps its broken off. What that button does is tells the washer the door is closed so it can go ahead and lock it to start the cycle,its perhaps broken off sothe machine doesnt think the door is closed and thusly wont start.
GENE
Oct 06, 2011 | Kenmore Elite 45986 Front Load Washer
My washing machine wont start it keeps saying door open i opened and closed door several times it continues to say door open. I unplugged it to see if it would reset but it didnt.
The door switch is likely broken from slamming the door. Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2010 | Frigidaire Affinity ATF7000E Front Load...
Samsung WF7700N6W1 wont start because of 'door' error, door is closed
there is a switch in the door latch that tells the unit the door is closed so it can start to operate if there is a fault or a peace of the latch has broken off the unit will read door open check the latch for any broken off peaces if it looks good replace the inter lock unit on the machine
Jun 19, 2010 | Samsung WF328AA Front Load Washer
Wont final spin
Most likely a door pin switch problem. The machine is sensing the door is open even if it may be closed.
The switch could be cracked or broken and needs to be replaced.
Mar 13, 2010 | Equator EZ 3710 CEE / W Ventless...
Door wont stay closed
Either the door catch or spring is broken, or the door lock is not working
The parts are fairly easy to fit,once you have determined what part or parts you require.
Hope this helps.
Dec 15, 2009 | Zanussi F1045W Front Load Washer
My washer is locked and cant open it at all
Probably door-lock is broken or motherboard crash.
If it not signalize that door are closed propertly it want start taking water to wash.
It's overflow prevention.
See user manual -> possible problems or call local serviser.
Aug 11, 2009 | LG WD-16115FD Front Load Washer
Door wont latch shut
Is there a dl code? If not note the door striker position as the door closes. If you have to push it shut you need a door lock and if the striker is hitting below the latch too much a hinge will fix it. Finally look for a black pin above the striker for any damage as the latch will need to be replaced if broken too. Because with this and a door hanging low will not close the circuit and the ccu will believe the door is open also.
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
HE3t wont start
open the top access panel, 3 screws in top rear.
start washer
push up gently on one of the center black wired connectors that connect to the control unit (in back top of washer)
if it starts to work then the relays on the control circuit board need to be re-soldered . a normal reoccurring issue
its rarely the latch
Mar 21, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
121 people viewed this question
Dan Webster
Dan Webster
Sal De
