ZENITH Z50PV220 CLICKS. WONT COME ON
SOURCE: Zenith E44W46LCD 44 in. Rear Projection (Wont Turn on)
I bought an open box unit at Best Buy, it had no remote or manual. Go to http://www.zenithservice.com/, click on owner's manuals, answer the 4 questions using drop down menus and then you can download an owner's manual and save it to your computer/burn it to a CD/print it out. If you choose to print it out, beware, the manual is 60 pages. One of the 4 questions they ask is "Product", choose Projection TV, not LCD TV. The 4th question is "Model Number", mine is E44W46LCD, is guess everyone's here is the same, duh.
For the remote, I looked in the phone book for an authorized Zenith TV repair company. I called them and gave the model number and paid over the phone. I had the remote shipped to my home address. The total including tax and shipping was $50. The remote they sent is a large Zenith mulit-function #6710v00102k. I don't know if that is the remote that would have came with the TV, it worked without having to program it first. It can control TV/VCR/Cable/DVD/Sat. I t has controls for 6 inputs, SAP, mute, Surf, Video, Picture in Picture, Ratio (16:9, 4:3, Zoom, etc), CC, Freeze, Menu, and controls for DVD and VCR (rewind, play, etc). If you can't find a place in your area to get the remote, Email me at [email protected] and I'll look up where I got mine from. It came from Palm Desert, CA.
I don't know about your TV not coming on, is it plugged in? If it is, that's about all I've got. Gregg
SOURCE: Zenith-ZEN400B-EIA343-SK16-002
the codees oyu seek and an easy guide on how to program it are here
http://www.remotecentral.com/features/r-zen.htm
SOURCE: programming remote
The BNZ110 is designed to be for Zenith by default. If it gets changed and won't work, then take the following steps.
1. Remove the batteries.
2. Hold the power button down for 10 seconds.
3. Reinstall the batteries.
This works for many Zenith TV's.
Here are the codes for Zenith if that does not work.
713 502 606 409 710 701 507 714 405 712 015 916 008 002 115 224 324 126 326 826 228 430 632 435 437 903 407 505
SOURCE: zenith executive laptop model no:z75110 mother board cd
I am having zenith z755110 laptop. I am not having the driver cd for that, pls anyone can me
SOURCE: tv turns on clicks but never comes on just clicks
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsun. Know to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio conections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
