Question about Brother MFC 3100C All-In-One InkJet Printer
It just wont work
My pinter wont do anything. it is designed to scan print fax and copy and it wont  do anything.it says michine error 41.what adoes that mean and what should i do.
    Scholar:
  • 121 Answers
Move the ink cartridge carriage (the printhead) to the middle of the printer like you're going to change cartridges.  Take out all the ink cartridges.  There should be two black springs on either side of the printhead.  Remove these and the printhead should pop out.  Clean the nozzels (the little parts that squirt out ink) and reassemble.
If this doesn't work, then you'll have to replace the printhead.
Posted on Oct 28, 2007
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
My hp deskjet f4140 will only scan and coy. It will not print anything from my computer. I used it last night and it worked fine , then it just stopped. Ive checked my devices and printers under my control...
is it giving any error while giving print command? goto start settings printer & faxes open the printer icon by double click .any job is pending in the queue? try remove the usb cable and check t below the pinter icon whether it shows off line?
Aug 04, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
Machine error 41
Very likely your print head is faulty. You can get it replaced or try the economical solution below.
I had the same problem after replacing the print head. I removed the ink cartridge and then unclip the two metal two clips by the side that hold the print head. Then I used WD40 to spray through the ink holes until the clear liquid comes out from the print head.Then I replaced everything back and start the cleanning process, do a few test prints. It works ok now, no more Machine Error 41. Therefore, sometime the problem might just be clogged pin heads!
May 15, 2010 | Brother MFC-3220C Plain Paper Inkjet Fax
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
Error 41 MFC 3220C
WELCOME TO THE ERROR 41 DELIMA. YOU WILL NEED A NEW PRINT HEAD, MAY BE U CAN BUY ONE FROM A BROTHER DDEALER AND INSTALL IT GOOD LUCK
Jan 27, 2009 | Brother MFC-3220C Plain Paper Inkjet Fax
Wont print anything
Oct 28, 2007 | Brother MFC 3100C All-In-One InkJet...
Brother MFC 3100C All-In-One InkJet Printer Logo
83 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
