Question about Sony XM-2200GTX Car Audio Amplifier
Amp LED light turns on then off
My system is hooked to a kill switch so i can turn off my amp and bass when needed. this prevents my amp from staying on. one day i turn everything on and the light turns green then shuts off. not red but just completely off. i checked my fuses and everythings ok. any suggestions?
  • Anonymous Dec 19, 2007
    HAVE THIS AMP AND ONE DAY IT FEEL OFF DUE TO VIBRATIONS ON THE BOX. NOW THE AMP STARTS GREEN BUT TURNS RED AND DOSENT WORK. NOW IVE CHECKED MY POWER GOING IN AND EVERYTHING IS GOOD ASWELL AS THE FUSES ARE ALL OK WHAT SHOULD I DO NEXT OR WHERE SHOULD I BRING IT
  • 631 Answers
You need to use a multimeter to confirm that you have both B+ and remote voltage at the amp.
Posted on Oct 29, 2007
How do you start 1993 bass tracker?
Bass Tracker? Bass Boat? If its a tiller motor, yank the rope until it starts, or, your arms fall off, whichever comes first! If its electric start, check your batteries are good & fully charged. Make sure your "kill" switch is connected & you're in neutral. Turn the key. In fact make sure you're in neutral for the tiller motor also.
Apr 28, 2016 | Miscellaneous
We installed the amp and bass package and the subs are not nowhere near *** powerful we think its the amp and when the remote bass switch when we turn it it doesnt change
what product brand did you install. do you set the amps x-over and gains a sub sonic filter right
need to see if the amp is on check led light on amp. make sure your subs ohm load is correct for the amp.
let us an example fake amp 500x2channel max output 1000watts
if you wire your subs at 4 ohms you 250x2 rms stereo
if you wire your subs at 2 ohms you 500x2 rms stereo
if you wire your subs at 4 ohm mono you get 1000 watts
if you have the input voltage of 14.4 all the time at the amp
whats the equipment power
Oct 14, 2010 | Car Audio & Video
Crate Bass Amp B100 - No sound.
Do you happen to have another speaker that you could hook up to speaker output? This would bypass the amps internal speaker and lf you get sound from that setup, it would mean either a jack failure or possible internal speaker problems. Please let me know.
Jan 24, 2010 | Crate Music
Boss bass 600 Amp comes on but does not have sound
yes and also moisture. i have had plenty of amps die like this on me! needs repair
Jan 06, 2010 | Boss AUDIO SYSTEMS BASS600 Car Audio...
The led on my lxa 600 watt amp in my dodge magnum
If the light is all that is on then it will be fine. It would take days to weeks for it to kill todays car batteries. If the amp is drawing more power than just that though, I would move the remote wire to the ignition or the headunit, because the fusebox is getting constant power to tell the amp to stay on.
Oct 10, 2009 | Car Audio & Video
I have a sony 100 watt amp and it wont stay on for very long
You need more current.Bass notes require more juice and the best way to get more power for bass is to add a power capacitor to your system . They are easy to install and you can get one for less than a hundred dollars that should be enough for your amp and subs.
Sep 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Jl audio 500/1 amp
You may have the amp set to turn on via an audio signal. Set the Signal Sensing switch to OFF.
Jun 13, 2008 | Jl Audio 500/1 Car Audio Amplifier
Adding aftermarket audio to factory amp.
yes it will kill your batery u need aremote turn on man dont messa round with out one
Feb 03, 2008 | Car Audio & Video
My amp turns on then off while it slowly blows the fuse out
If I were a guessing man, I'd guess that you had your amp hooked up in a bridged configuration. And also that you connected your two speakers in parallel (plus to plus and minus to minus). And if I were to further guess, I'd guess that you have a blown amp now because of what I mentioned above. Sounds like you need to spend some quality time with your favorite electronic repair shop. Good luck.
Feb 23, 2007 | Hifonics BXI 1606D Car Audio Amplifier
Sony XM-2200GTX Car Audio Amplifier Logo
173 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
