Question about Maytag 24 in. MDC5100A Free-standing Dishwasher
Maytag Dishwasher Blinking LEDs - "Freestanding" Electronic Control
My Maytag “Freestanding” dishwasher won't start a cycle and has Blinking LED lights on the front.  It worked fine yesterday.  Model Number: MDC5100AWW.  Serial Number: 27379485AE   Control Type: Electronic
The following two LEDs are blinking:
- LED above the "Heated Dry" button
- LED for the "Clean" icon
They are both on constant synchronized blink (NOT providing specific number of blinks to indicate a code).
I bought the dishwasher new in 2001 and it has never had a problem prior to today.
May or may not have contributed to the issue:  Yesterday I ran the dishwasher using the "rinse only" cycle to rinse the cups with only water.  During the middle of the rinse I needed to get water from the faucet, so I removed the plastic attachment that holds inlet and outlet hoses to the opening of the kitchen faucet. (It
5 Suggested Answers
  • 142 Answers
SOURCE: Electronics problem with Maytag Dishwasher
the outlet pump may have become clogged, try removing and cleaning it.
Posted on Jan 27, 2009
  • 256 Answers
SOURCE: I have a MDB5130AWW model
You may have a seized/stuck motor. Turn the electricity off and remove the lower panels. Take a flat head screw driver and carefully attempt to move the motor impellers. If the impellers feel hard to turn continue to try and free the impellers. If they loosen, reactivate the power and start the appliance. Good luck!
Posted on Feb 25, 2010
rylee_smith
  • 8619 Answers
SOURCE: Model no. MDB6100AWW. Just unloaded the
Hi
Thanks for using FixYa.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
If still the issue is not resolved then you'll have to replace the control panel. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 07, 2010
Macmarkus
  • 2605 Answers
SOURCE: Maytag, MDB9100AWW, Serial # 13125545WZ.
Hello, welcome to FixYa.
I'll start by saying the "2" in the display when you press cancel is normal. If you allow it to complete it should initiate the drain before you press cancel the second time.
Initially It sound's like a fill valve or stuck float assembly, though there are many possible scenarios that can include a heating element or a control board, so I'll need to clarify the unit will indeed complete the cancel if you do not push it the second time and if it does complete the cancel will it then in turn start a new cycle ?
Let me know what you find or if you can add any further details and I'll try to help moving forward any way I can. Good luck.
Thanks for visiting FixYa.
Regards,
Macmarkus :)
Posted on Jun 16, 2011
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
Maytag dishwasher mdb7100aws is flashing clean-lightwash-heated dry
I have a Maytag MDB7100AWS which suddenly started blinking the following LEDs: Clean, Rinse Only, Regular Wash, Tough Scrub and Heated dry. Tried cycling the breaker, no help. Tried the key sequences in the troubleshooting sheet behind the kick panel, no help. Then happened to press the Drain/Off button twice. All LEDs went out and am now on my second successful load, fingers crossed. Suspect the control board got latched up somehow.
Jan 25, 2012 | Maytag Dishwashers
Crosley CDC610B Freestanding dishwasher The dial hums when I try to start the dishwasher. If I open the door and bang on the inside of where the timer is a few times, then slam it shut, the dishwasher...
I am a homeowner. I am not familiar with that model. I have a built in Maytag dishwasher and the timer is on an electronic circuit board. Yours sounds like a mechanical timer, may have plastic gears/moving parts similar to the timer on my maytag dryer. You will have to open up your door and expose the timer. I would imagine it will have a wire harness. Without knowing the anatomy of your dishwasher, I would imagine there are screws securing the interior panel (facing the inside of the dishwasher) to the exterior panel. You may need to remove all or some of these screws to expose the control panel's guts (which includes the timer) On my dishwasher only the top screws needed to be removed. I was able to replace the circuit board and get my dishwasher working again. Once you expose the timer you can go from there. I found a link: https://www.ebay.ca/b/Crosley-Major-Appliances-Parts-Accessories/20710/bn_3163310 that may be of help. Good luck!
Nov 08, 2017 | Crosley CDC610 Free-standing Dishwasher
Maytag mdb/c-2 some lights are blinking and won´t stop. I can´t start the cycle of cleaning, well really i can´t start anything. Please any sugestion ?
press the "off" button and hold it down for several seconds. this worked for me when i encountered the same problem on my maytag jetclean this weekend. it reset my control panel and now it's working great!
Sep 11, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Clean light is blinking. dishwasher won't turn on
it is a problem with the heating cycle.Dishwasher “Clean” Light Blinks 7 Times The electronic control looks for a temp. rise of 2° - 4° F.
If no temp rise, the control assumes a heater fault and blinks the clean LED 7x.
Check the heater circuit, water fill, wash pump operation, and neutral side door
switch.
Run a Diagnostic Cycle to reset the control.
REPLACING THE CONTROL WILL NOT RESOLVE THE CONDITION.
All Electronic Controls
S.O.P. – Standard Operating Procedure Whenever an electronic control is suspected
to be the cause of a product failure: before replacing the control, disconnect and then
reconnect all of the wiring harness connectors to ensure proper electrical contact.
I hope this helps.
Jan 24, 2010 | KitchenAid Dishwashers
Control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
Sep 17, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Sep 01, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Maytag 24 in. MDC5100A Free-standing Dishwasher Logo
64 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
