2000 Oldsmobile Bravada Logo
Anonymous Posted on Jun 11, 2009
2000 Old Bravada - key won't come out
I have a 2000 Old Bravada. Every so often, 3 times today alone, when I stopped, put the shift into park, and tried to turn off the vehicle, the key wouldn't turn all the way back to come out. Typically, when I put the shift into park, I hear a metalic "click" in the steering column, and I can turn the key back and remove without incident. When I put it into park, and do not hear that sound, without fail, the key won't come out. Smetimes it can take up to 5-30 minutes of turning the wheel, and jiggling the key before it will turn back and come out. I have been given conflicting advice on what it is. One mechanic says it is the barrell and it needs to be replaced; one mechanic says it is a "spring" in the floor shifter keeping a plate from sensing the car is in park, so it won't release the key; and one other mechanic said the entire plate and cellinoid need to be replaced, at a cost of $900. The transmission is fine. how would I fix or bypass.
  • 1 more comment
  • Anonymous Jun 11, 2009
    Floor.
    Floor Shifter. would replacing the ignition switch solve the problem. because I've heard that one too.
  • Anonymous Jun 17, 2009
    Thank you man. I'm tired of having pull the keys out of the ignition and unhook my battery.
Anonymous
Level 3:
Brigadier General:
  • Master 4,669 Answers
  • Posted on Jun 11, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
4669
Questions
0
Helped
1845389
Points
16674
Do you have a floor shift or column shift? I'll look up the wiring to tell you how to byapass it.
    No the problem is likely the shift interlock solenoid on the shifter. But I'll look it up.
1 Related Answer
Anonymous
  • 4669 Answers
  • Posted on May 27, 2009
SOURCE: key won't come out of 2000 bravada
This is a floor shift? Have you noticed the transmission sticking in third? Do you feel you have the ability to take the shifter apart? It's a problem with the shift interlock solenoid. If the transmission is sticking in 3rd also it is a power supply to the solenoid from it ignition switch. If the transmission works fine I can tell you how to fix it or bypass it.
2answers
Why can't I turn the ignition (switch) off?
make sure its in park. also if you have 10 pounds of junk on your key rings the lock is worn out now.
1helpful
2answers
My smart key will not turn in my ignition on my clk320 year 2000 battrey was flat but it as been charge up and tested
sounds like a bad key and needs to be replaced. you cannot take it out of park unitl the key is rotated.
2011 sonata shifter won't lock into place
Do you have a warranty?If so take it back,it may have a recall.
2answers
Ignition switch won't release key when it is put in park. But when I removed switch and key tumbler, the key tumbler/cylinder releases key. Why won't the key release when it is in park?
Most newer models have a safety feature called
shift interlock. This prevents the key from being turned back
to the lock position if you forget to place the gear selector in park.
Depending on the model,
If it uses a cable, it may be sticking or needs adjusting.
If it uses an electrical solenoid. may be blown fuse or park switch.
Tap, shake, and pull up on the shifter and make sure it's in park.
2answers
94 olds bravada, key stuck, won't start
does every work properly with the wiring to the trialer disconnected? (un hook the wiring to trailer and put back the way it was) and let me know
4helpful
Key won't come out of 2000 bravada
3helpful
3answers
Bravada truck ignition key will not turn truck off while in park
I had been trying to figure this problem for myself too..it seems to be Brake Transmission Shift Interlock..you can research it and here is a link you can try its very promising.http://answers.edmunds.com/question-How-I-bypass-BTSI-1998-GMC-Jimmy-31994.aspx
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you an Oldsmobile Expert? Answer questions, earn points and help others
