Question about Hotpoint Ultima WF860 Front Load Washer
How do I replace the belt that makes the drum spin on a Hotpoint Ultima WF860 ?
It's slid off, but I don't know where to put it back on!
  • 146 Answers
The belt goes around the drum and onto the motor pulley. No need to loosen anything. Put tension on the belt and fit it onto the motor pulley by gently turning the motor and pushing the belt onto the pulley at the same time.
Posted on Nov 01, 2007
There is an interlock that prevents the shredder from operating without the bin in place. Something may be jammed in the interlock or the bin may not be closing the interlock as it is slid in place.
Feb 13, 2015 | Shredder Office Equipment & Supplies
Putting the shelves and drawers back
crisper drawers the rails need to be slid front till they clip in.
shelf but back part in then slid back and clip in front.
Apr 04, 2014 | Bosch Refrigerators
Wt741 machines drum
It is possible the motor start capacitor has failed. Unless you know how to test it, call a service person.
Oct 19, 2013 | Hotpoint Ultima WF860 Front Load Washer
My washing machiene isn't spinning
The brushes or bushes as some people call them have worn down
to low very easy to replace if you can find some for your machine.
there on the motor held in with little springs pull them back and slid the brushes out and make a note of the bevel on the end disconnect from the motor then slid new ones back in the same angel of the bevel and rereconnect put the sping back(some times the spring is connected to the brush it self) plug the machine back in job done.
Jan 30, 2013 | Washing Machines
Fabric quit feeding through
there called feed dogs & if they don't feed the fabric thur the machine need they need to be check to see whats wrong with them
Mar 07, 2012 | Singer 3116 Simple
After downloading SD to computer i replace disk into camera and camera screen noe reads "card locked" this has never happened before and i don't know how to fix it
There are a few reasons for this and the most common is that you accidentaly slid the lock switch on the card. Look carefully for it and slide it back the opposite direction
the other major cause would mean that card was corrupted by the computer from either removing it before all transfers were complete or in some more extreme cases a virus can also lock some cards.
If it is not the switch then suggest get a new card
Nov 01, 2011 | Polaroid I1037 Digital Camera
I'm trying to figure out how to load #10 envelopes to print.
Generally, since you have not mentioned what printer you are using, remove all the paper.
Slid the enveople into the bottom of the paper tray, face side down (flap up) and the flap to the left. Push the envelope to the right side of the tray and as far forward until it stops.. On the left side, you may have a rail that will slid to the right against the envelope.
or The paper tray may have a slot on the right near the back. Slid the envelope into that slot, flap up and to the left, as far as it will go.
Once the envelope is put in place, run the software that you use to print.
Jun 03, 2011 | Office Equipment & Supplies
Hi, I was wondering if anyone can tell me in detail how to remove the casing of a hotpoint wd860 ultima so I can access the belt pulleys to replace the belt. Totally stumped and have hurt my finger this...
jon you would have to remove the drum and you don't want to go to that hassle to fit a belt.
try this out
  1. remove lid
  2. remove back inspection panel
  3. from top of machine fit belt around motor pulley
  4. half fit belt to the drum pulley
  5. Here's the tip, get a cable tie and secure belt to drum pulley, may need to use 2 ties
  6. now slowley rotate drum and belt should slip straight on
when your not used doing this sometimes a good idea to remove the top weight, 3 13mm bolts. this will give you more room.
hope this helps
Mar 17, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
510 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
