Question about Brother MFC 3100C All-In-One InkJet Printer
Wont print anything
It keeps saying machine error 41 to unplug and call brother but i lost my sheet that had the number on it nad so i cant copy, print, scan, or fax.
  • 2 more comments
  • KARUKARUKA Jan 07, 2008
    KEEPS ON DISPLAYING ERROR CODE 41
  • Inca123 Feb 26, 2008
    Says Error 41. Cannot Print copy or scan. I can however still fax out. It just takes some time for them to receive it. Like 20 min. Also says to unplug and call brother. I lost the number tho
  • tony1940 Mar 20, 2008
    same problem
  • alvin miles Apr 27, 2008
    dont have a phone # i did try unplugging it.
Just buy a new printer. These are junk an will do the same thing with a new print head in about the same time as your last one did. Screw Brother!!!
Posted on Jan 10, 2008
    Scholar:
  • 121 Answers
Move the ink cartridge carriage (the printhead) to the middle of the printer like you're going to change cartridges.  Take out all the ink cartridges.  There should be two black springs on either side of the printhead.  Remove these and the printhead should pop out.  Clean the nozzels (the little parts that squirt out ink) and reassemble.
If this doesn't work, then you'll have to replace the printhead.
Posted on Oct 28, 2007
Error 41 brother all in one :Performed Print Quality Check Sheet $ times. The test sheets became closer and closer to being 100% correct, then error 41 pops up
Machine error 41 is "defective print head".Try to turn off the printer and wait 10 min.Then turn on, if the error continue showing your printer need service.
Oct 13, 2009 | Brother MFC 420CN All-In-One InkJet...
Wont clean, wont print, says to see user guide, cant find paper jam or foriegn objects, starts to do clean then stops and says unable to clean
Unplug the device from power cord, then press and hold the menu button.Plug back the device.On the LCD you'll see the "machine error" code.If this code is "machine error 40, 41 or 4f" the print head is defective.If the machine error is 46, this is the waste ink tank full.Then follow this procedure:
1. Pres 'menu', 'mono start' then'menu' one by one...
2. Press the arrow up or down to go to'maintenance 80'.
3. Press 'mono start' several times to go to'Purge'. Finding the PURGE will show some numeric value which is Iassume the number of times the printer had cleaned.
4. Press'arrow up' key and scroll for number "2" then press "set".Do the same for numbers 7, 8 and 3. After you have entered thiscombination, the purge numeric value will be reseted to 00000.
Oct 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
My fax mfc3220c say message error 41 when I turn it on. It also say unplug and call brothers
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement. My advice is to take it to a
Brother service centre while it is under warranty. If it's out of
warranty then it is cheaper to purchase a new, non Brother model. If you have been using non-Brother cartridges or refills, they can have too much water in them and it erodes the print head after a while. Usuall y just after warranty has expired!
Feb 18, 2009 | Brother MFC-3220C Plain Paper Inkjet Fax
Fax machine says error 41 unplug and call brother.
unplug all the connections and reconnect everything back.also checkout for any blocked paper or any paper jam.also remove and check out the cartridges from the printer and reinsert.either its the internal circuit failure error and has to be repaired to make it proper. thanks.
Dec 15, 2008 | Brother IntelliFAX 1800C All-In-One...
Brother mfc 420 cn
if you have an error 41 the machine wont print any more due to a short circuit in the print head.
plz check error message.
anyway, if you have received error 41 you need a new printhead or better (because its cheaper) a new mfc.
sorry!
Feb 13, 2008 | Brother MFC 420CN All-In-One InkJet...
BROTHER "MFC-3820-CN" TROUBLESHOOTING
You need a new print head.
You could try cleaning the one on there, but all brothers similar to yours are plagued by this problem.
To clean it try:
SWITCH MACHINE ON WHILST HOLDING DOWN MENU/SET KEY, THIS PUTS MACHINE INTO FACTORY SETTINGS MODE.
(MAINTENANCE WILL SHOW ON LCD)
ENTER CODE:84 & WAIT WHILE MACHINE PERFORMS A FORCED CLEANING CYCLE.
(cLEANING WILL SHOW ON DISPLAY)
NOW ENTER CODE:09 & MACHINE WILL PRINT OUT ITS PRINT QUALITY CHECK SHEET.
(IGNORE INSTRUCTIONS PRINTED ON CHECK SHEET)
CHECK QUALITY & REPEAT BY USING CODE:84 IF NEEDED.
(YOU MAY HAVE TO DO THIS SEVERAL TIMES BUT YOU SHOULD SEE A STEADY IMPROVEMENT WITH EACH CLEANING CYCLE)
WHEN FINISHED AND QUALITY IS GOOD, ENTER CODE:99 TO RETURN TO STANDARD MODE.
PRESS MENU/SET 4, THEN MONO FAX START TO PRINT OUT
PRINT QUALITY CHECK SHEET & FOLLOW ON SCREEN INSTRUCTIONS.
Feb 11, 2008 | Office Equipment & Supplies
Will not print
You have a major error, probally head stuffed error 41, to find out your error press menu starte and up 4 times, this may show error if not then input 82 set, error will display.
Post back if need more info
S.
Jan 14, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-3220C
Error 41 is Print head needs to be replaced, on this model it is not a big job, Heads can be purchased from Brother dealers, ring brother to locate if you wish to repair this machine rather than replace it.
Head sells for about $80 for the part from a brother dealer 1-800-284-4329 and it will need a new set of inks too, not really worth it just replace with new machine with ink and a warranty.
Very common issue, brother extended warranty for this fault for two years but yours would be past it by now, the s/n tells of build date, the first two digits of the LAST NINE of the serial number indicate build date, so a K6J702822 ending serial no. means it was built K6 = Nov 06.
I beleive that this is a result a lot of the time by the use of refills and remanufactured ink cartridges being used.
There is heaps of info on net regarding "error 41".
Nov 15, 2007 | Brother MFC 3220C All-In-One InkJet...
Unable to print
Brother Error Codes
RAM clear (most models)
Quickly press function * 2 8 6 4
Display should read maintenance
Press 0 1 for a full ram clear, or 9 1 to retain user data
Display should read reinit for a few moments then redisplay maintenance
Press 9 9 to exit the maintenance mode
Other maintenance mode switches:
01 ram clear (see 91 below)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
B2 error = scanner or power supply error
Brother 950/980: On copy or transmit they may produce black pages. Prone to bad scanner (CCD). Brother may provide a replacement CCD at no charge to the original owner. Sometimes leaving the unit unplugged for a few hours will solve the problem temporarily.
Brother HL600 series laser printer toner will work in the laser fax & multifunction machines (part number TN100HL = TN100PPF). Drum units may be interchangeable as well (?).
Brother 1350/1550/1950: Problem: Record paper jams. Solution: Replace upper shoot. P/N UF6058001. Although there seems to be nothing causing the jam, the upper shoot gets stress marks on the ends. Replace even though it is not broken. (Thank you David Price, dyprice@earthlink.net)
Thermal Transfer Machines: Only one side of the page is printing. Caused by the printhead latch being cracked. The latch is blue in color there is one on each side of the printhead, replace both latches
Nov 04, 2007 | Brother MFC-3240C All-In-One InkJet...
Machine Error 41
Error code 41, Print cartridge is bad and gone out. Needs to be replaced by authorize dealer for just under $100.00 ($55.00 part & $40.00 Labor).
Nov 14, 2006 | Brother IntelliFAX 1800C All-In-One...
Brother MFC 3100C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
