Question about Uniden Radio Communications
BEARCAT BC120XL I NEED TO PROGRAM CHANNELS I AM ONLY GETTING THE WEATHER STATION
  • vince durham Mar 17, 2008
    only getting weather channel
Mechanic688
  • 204 Answers
SOURCE: i need to know how to program channels into it
HI again, the 248 is only a 50 channel, do you need this info for the 860? If so, I answered in your other post, but here it is again.
Hi tina33, I have an 860 scanner,and this is how I do it. If there is no freq's in there yet, start on channel 1 and punch in the freq- hit E and it will enter it into the first channel. Hit manual to go to ch 2 and repeat. If you need freq's for your area, go here and search out your state and county and it'll give you a list of freq's for your county.You do not have to add the weather channels as their in there already, just hit the weather button. I use an external antenna on mine as it extends the range and allows me to pick up the cars as well.
http://www.radioreference.com/apps/db/
If you need a book for your scanner, you can get one here, just print1.gif it out.
http://www.uniden.com/pdf/BC860XLTom.pdf
Hope this helps,, Mechanic
Posted on Jan 23, 2008
SOURCE: programing scanner
reset bc860xl
Posted on Jul 17, 2008
freetek
  • 5568 Answers
SOURCE: bearcat 50 channel scanner
Your model number doesn't seem complete so you will have to research it on this page:
Uniden Manuals
If you can find it, the download is probably free.
Posted on Feb 20, 2009
  • 27 Answers
SOURCE: need programing instructions
try this website here it has all uniden products http://www.uniden.com/index/manuals_results.cfm?cat=3 i believe it uses the same manual as BC248CLT
Posted on May 16, 2009
BillB-SA
  • 2761 Answers
SOURCE: I have a Uniden bearcat scanner and cant remember
Although you didn't specify a model, your problem is listed in the BC95XLT section, so here is a link to the manual for that scanner. It's a pdf file that you can download/print for future reference.
http://uniden.com/pdf/BC95XLTom.pdf
If this is not the correct model you can find manuals for most recent Uniden scanners on the same site.
Posted on Aug 16, 2009
I have the 58" 4K tv, and I'm getting really bad lip syncing issues, tried the TV menu and it door nothing. Anybody acn shed some ligh? TH brisbane
this is an issue of the signal carrying the sound is not synced with the picture
can be a station transmission problem or weather condition
if it is the same on all channels , take your unit in for a proper diagnosis and quote but I find that normally changing channels for a while will fix it
check the aerial for correct alignment to the station as it could have moved in the winds
Jul 16, 2016 | Televison & Video
Display station not showing outside temperature
Check battery status indicator on main weather station of remote unit. If no indication, replace battery in remote unit. If battery is good then check "channel setting" of remote unit to make sure the channel setting on remote unit matches the "channel" setting on main unit. many weather stations will take up to 3 or 4 remote units and they must use different channels to relay the remote imfo to the main weather station unit.
Jun 19, 2015 | Measuring Tools & Sensors
Is there a sharper image internet weather station download for windows 8, I seem to be only getting a downlaod for Win XP Prp?
Hello, You will have to go back to the weather stations tech or cust. support to get that question answered. Just make sure you have your model and serial number or your weather station written down too tell them.
May 17, 2014 | Sharper Image 5 Day Weather Forecaster
No weather information
It sounds like you may need to program your location into the radio. Follow these steps to do so.
1. Turn switch on side of radio to "ON".
2. Press "MENU".
3. Press "UP" arrow until "CHANNEL" is displayed.
4. Press "SELECT".
5. Press "UP" arrow until you hear the broadcast of your station.
6. Press "SELECT" to save station selection.
7. Press "MENU" to close menu mode.
To turn Weather/Hazard broadcast on again, press "WEATHER/SNOOZE".
Jan 02, 2011 | Midland WR-100 Weather/RDS Radio
How do i program the radio to only give audio alerts for the county in whitch i reside? (sarpy county in nebraska
2. Press "MENU".
4. Press "SELECT".
Note you will hear only static on the channels not received in your area.
(FYI - channels are listed 1-7 on the left, and corresponding frequency numbers are displayed on the right side of display.)
At This Point You Will Receive Weather And Hazard Alerts Issued By The NWS.
Dec 24, 2010 | Midland WR-100 Weather/RDS Radio
I have had my radio for a while and now just out of the blue the weather band stopped recieving or something, the rest works fine the wx led even lights up just no audio
If there is static noise, then it's probably not the weather board. We have had something like this happen in our area....
The closest weather station to here up and quit transmitting. The transmitter died after years of use. So all of a sudden there was not weather station. It was out for months.
If there is no noise at all, then there is probably something wrong with the weather board. I don't mess too much with weather boards my self. You could look at the weather channel selection knob and look and make sure all the wires are connected, also the switch to turn on weather.
Nov 10, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 75 wx st everything seems to work eccept receiving signal meter will spike on trx and it seems to receive but no sound there is sound in wx mode
WX is for weather. If you put it on WX, and you do not hear anything, then you need to change the weather station it is on. in wx mode, you change weather channels by pressing channel up and down. To communicate with 2 way, press the cb/wx button so it is on CB mode.
Sep 28, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
No more TV on Sony TV/weather/fm/am walkman srf-m37v.
There's nothing you can do. With the switch to digital broadcasting, the sound isn't on the same frequencies it used to be so this radio can't pick it up. Right now, nobody's offering a digital receiver for the sound. All your radio is good for now is the regular radio and weather broadcasts.
Jun 16, 2009 | Sony Walkman SRF-M37V AM/FM/Weather/TV...
Programming the BC244CLT
Hi, If I'm reading correctly, that scanner is listed as a 30 channel scanner only. You can pick freq's from 10 different bands. Here's just some of the features listed, hope this answered your question.
Mechanic
FEATURES:
  • Clock/Alarm - Large backlit LCD displays time and features "any button" snooze.
  • 30 Channels - You can program each of these memory channels to store one frequency.
  • 10 Bands - Including all public service bands, 4 "HAM" bands, federal and military land mobile bands.
  • Weather Scan - Automatically scans all national weather service frequencies.
Jan 17, 2008 | Uniden BC244CLT Base Scanner
Radio Communications Logo
73 people viewed this question
Top Uniden Radio Communications Experts
Steve
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
