Question about HP PSC 2355 All-In-One InkJet Printer
Printing problem I installed a new color cartridge and documents print in reds and black.
    Master:
  • 619 Answers
Your printer need head cleaning /
1. Nozzle check monitor the exact color to print / if one of the color missing or line color the printer head ned cleaning ,.
2. Proceed for head cleaning /press head cleaning
3.Nozzle check again after the color complete /test print w/picture
Posted on Jan 07, 2008
SOURCE:
Please let me know the direction of cartridges
You can follow the steps below to replace your ink cartridges.  Feel free to click on the link at the bottom to pull up a document that gives you information including pictures on how to replace the ink cartridges.
To take out the old ink cartridges:
When replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.When replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.Pull the print cartridge toward you and out of its slot.
To install new ink cartridges:Remove the new print cartridge from its packaging.Remove the plastic tape by using the pink pull tab.Slide the new print cartridge forward into the empty slot. Then gently push the upper part of the print cartridge forward until it clicks into the socket.When installing the tri-color print cartridge, slide it into the left slot.When installing a black print cartridge, slide it into the right slot.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00620122&cc=us&lc=en&dlc=en&product=1138373&tmp_track_link=ot_search
Apr 19, 2011 | HP Officejet 4355 All-In-One InkJet...
No red
the color red is a mix of two color. so run the cleaning tool on the printer
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_541ceb86d69e7743
Dec 12, 2009 | HP PSC 2175 All-In-One InkJet Printer
Ran out of color ink on cnnon mx310 ... want to
If when you attempt to print only with the black cartridge installed but it won't print, then this specific printer requires that color ink also be installed. Typical with most inkjets.
Jul 07, 2009 | Canon MX310 Office All-In-One Printer
Color Document not Printing in color
yes your printer can print in black if you don't have black ink in the catrige but don't remove the catrige in the printer but it we print in deep arsh not as black.
Nov 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Lexmark X1100 printer will not print black
I came up with a work around for printing black.
I changed the black cartridge with the color cartridge.
Then when I have a letter to print, I change change (or write) the letter text to yellow, red or blue.
Then I can print out a letter.
By printing the text as yellow, red or blue the cartridge will try to print with only 1 color, but will print out black.
If you do not use one of these primary printing colors the out put will be unusable.
I can not of course print out pictures.
Oct 04, 2008 | Office Equipment & Supplies
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Black printing morphs into red after black ink cartridge installation
Your printer creates it's black by using ALL the colours together. This effectively gives a very dark purple rather than black.
It sounds like you have a colour cart that is drying up or may be struggling to get enough air into the cartridge. Make sure you have removed any tape over the vent holes if you are using compatible inks. If not then try running a couple cleaning cycles via the button panel/driver.
If you alter the settings in the driver by going into START - PRINTERS AND FAXES and then right click on your 2610 and select PROPERTIES - the changes you make in here will be set as the default settings for each print job.
Oct 17, 2007 | HP Photosmart 2610 All-In-One InkJet...
Use of black ink
My husband answered this for me- it takes different colors to make black, therefore it uses some of the color ink
Jan 16, 2007 | Canon Pixma iP6600D InkJet Photo Printer
HP PSC 2355 All-In-One InkJet Printer Logo
369 people viewed this question
Clive
Clive
Thomas F. Schneider
