Hi
I have a pulsar solar watch that I purchased in florida three years ago and it has started to stop every few days. The only way I can get it to work is by putting it under a light overnight, then it runs for a few days.
Any Ideas
Regards
Jen
I have the same watch and the same problem. The solar battery is depleted. You need to recharge the watch like you did when it was new. The instructions can be found through the following link: www.pulsarwatches.com.au/manuals_pdf/108_1.pdf
I was reading the battery replacement procedures for the Garmin Forerunner 50 and have an alternate...
(More)
I was reading the battery replacement procedures for the Garmin Forerunner 50 and have an alternate observation.
To remove the spring clip that hold in the battery and plastic, place your thumb over the middle of the spring and gently press and slide the spring in a 7:30 to 1:30 direction. The spring pops out and the battery can be removed. NO PRYING IS NECESARY. Replace the battery. The spring is replaced by setting the 7:30 end in place and then sliding the 1:30 end in to lock it.(similar to the removal but in reverse). I hope this helps!
wva-470de-2avef. I have the above watch and for about two weeks now the analogue second hand and the...
(More)
wva-470de-2avef. I have the above watch and for about two weeks now the analogue second hand and the seconds on the digital display have been out of sync by about 2 seconds - How can I resolve this issue
How do you get the back off a men's armitron watch to change the battery? Took it to Walmart and...
(More)
How do you get the back off a men's armitron watch to change the battery? Took it to Walmart and they can't figure it out.
I have purchased a new Casio Model 2515 watch and the alarm rings so softly as to be useless. Any...
(More)
I have purchased a new Casio Model 2515 watch and the alarm rings so softly as to be useless. Any ideas as to how to increase its volume?
