Question about Sony PlayStation 2 (PS2) Console
DISPLAY THE PS2 HAS TO BE LEFT ON SO IT CAN HEAT UP AND THEN AFTER ALMOST 5 MINUTES HAS PASSED WE PRESS THE RESET BUTTON AND IT TURNS ON
  • 328 Answers
Invest in a canister of compressed air found at many electronic stores. You should spray it into any slots or holes that you see to clean out the dust. Dust inside the unit can cause overheating. Make sure you have good air circulation around the system.
Posted on Oct 28, 2007
Why does the projector keep going to standby mode?
If the lamp usage time has passed 2 000 hours (when LAMP POWER has been set to NORMAL), the projector will switch to standby mode after approximately 10 minutes of operation. The resetting procedure should thus be completed within 10 minutes.
1. Insert the power cord plug into the wall outlet and then
press the MAIN POWER switch.
2. Press the POWER button so that a picture is projected onto
the screen.
3. Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
4. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
5. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, "LAMP RUNTIME
RESET." is displayed and select OK.
6. Turn off the power.
This will reset the cumulative usage time for the lamp
unit to zero.
Mar 12, 2011 | Panasonic PT-AX100U-EC DLP Projector
What buttons change time display
How do I set the clock?
A5
There are several methods to set the clock, depending on the model.
Method 1
Press and hold the BAND and DISPLAY buttons to display the clock
Press and hold the BAND and DISPLAY buttons until the time display flashes
SEARCH left to adjust the hours; right to adjust the minutes
Press BAND button to store the time
Method 2
Same as Method 1, except press DISP to store the time
Method 3
Press ADJ
SEARCH left or right to select clock and press ENT
SEARCH left or right to select the hour or minute
Turn rotary knob clockwise or counter-clockwise to set the correct time
Press enter to store the time
Press ADJ to return to the previous mode
Method 4
Press and hold the BAND and FUNCTION buttons to display the clock
Press and hold the BAND and FUNCTION buttons until the display flashes
Search left to adjust hours; right to adjust minutes
Method 5
While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
Press the CLOCK knob to adjust the minutes
When the CLOCK knob is released for 5 seconds, the hours will flash
Press the CLOCK knob to adjust the hours
When the CLOCK knob is released for 5 seconds, the time will be stored
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
go to this web site for any thing about ur stereo
http://www.clarion.com/us/en/support/faq/Audio/index.html
Feb 18, 2010 | Clarion Car Audio & Video
TO reset service interval-BMW320d
1. With the key out of the ignition... press and hold the left odometer button.
2. Turn the key to position 1... Meaning radio turns on, but instrument cluster warning lights stay off.
3. Keep holding the button for a few seconds (5-10) untill the display changes and says any of these words... OIL SERVICE or INSPECTION with RESET or RE.
4. Release the button but then again press it and hold (about 5-10 seconds) untill RESET or RE flashes.
5. While the display flashes press the button one more time briefly, and if done correctly the words "end SIA" will show up in a few seconds.
Dec 18, 2009 | 2005 BMW 3 Series
I have a STOP message on the oven display. The user manual refers me to the product description sheet or the electronic programmer description, neither of which I have. The oven is not working at all while...
HI. This is a control fault, that may be corrected by simply shutting down the appropriate circuit breaker for 5 minutes. This will DE-energize the control board. Once the 5 minutes have passed, simply re-introduce power to the unit. If the unit continues to produce the error, this will confirm that the main control board has failed. it should be replaced asap.
Nov 04, 2009 | Whirlpool RBS275PD Electric Single Oven
Fix my clock pioneer deh-1500
For most Pioneer single CD players, you can set the clock using the following steps:
1. Press and hold the SOURCE button until the unit turns off.
2. Press and hold the FUNCTION button, until display pops up, then release. (If you do not have a FUNCTION button, then push the AUDIO button)
3. Press the FUNCTION button again until the clock shows on the display.
4. Press the UP and DOWN buttons to adjust the hours.
5. Press the LEFT or RIGHT arrows to move to the minutes.
6. Press the UP and DOWN to adjust minutes.
7. When complete, press the SOURCE button to exit.
Hope this helps!!!
Oct 23, 2009 | Pioneer DEH-1500 CD Player
Need instructions for my sr927w accurist watch
QUICKSTART - SET THE TIME
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three
seconds. The hour and minute hand will retract to the 12
O’clock position.
3. Select the time zone on the digital display by pressing the
upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of
the digital display will start flashing. Press the
bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds
flashing on the lower half of the digital display. Press the lower
left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes
flashing. Press the lower left button to set the minutes to your
current time.
7. Press the upper right button. You will see the hours flashing.
Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H
flashing. Press the lower left button to switch between 12 hour
and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR
indicator points to CAL.
2. Press and hold the upper left button for three seconds. The
hour and minute hand will retract to the 12 O’clock position.
4. Pull the bottom right button out one click. You will see the
month flashing on the digital display. Press the lower left button
to change the month.
5. Press the upper right button and the date will begin flashing.
Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing.
Press the lower left button to change the year.
7. Push the lower right button back in.
SET THE ALARMS
indicator points to AL1, AL2 or AL3.
4. Pull the lower right button out one click. You will see ON or
OF flashing on the digital display. Press the lower left button to
turn the alarm on or off.
5. Press the upper right button. You will see the hours flashing.
Press the lower left button to change the hour.
flashing. Press the lower left button to change the minutes.
SET THE TIMEZONE
1. Setting the time zones allows you to add or remove cities on
the digital display or switch between daylight saving and
standard time. Begin by pressing the lower right button to move
the mode hand indicator to SET mode on the bottom dial.
2. If the hour or minute hands are obscuring the digital display,
press and hold the upper left button for three seconds. This will
cause the hour and minute hand to retract to the 12 O’clock
position.
3. Now pull the lower right button out one click. You will see the
digital display flashing. Press the upper left button to select
SET to display the city or OFF to not display the city. Press the
lower left button to turn summer time on or off. Summer time is
indicated on the lower part of the digital display. Daylight
savings time must be manually set for each city.
4. Pressing the upper right button will allow you to scroll
through all the cities. After setting, push the lower right button
back in.
USING THE TIMER
1. Press the lower right button to move the mode hand
indicator to TMR mode on the mode dial.
position.
3. Pull the lower right button out one click. You will see the
minutes flashing in the digital display. Change the minutes by
pressing the lower left button. Once you have set the minutes
on the timer, push the lower right button back in.
4. Pressing the upper right button starts and stops the timer.
5. Press the lower left button when the timer is stopped to reset
the timer to its initial preset time.
USING THE CHRONOGRAPH
1. To use the chronograph press the lower right button to move
the mode indicator hand to CHR mode on the mode dial.
3 .To start or stop the chronograph press the upper right
button. If you press the lower left button it will display the split
time for 10 seconds.
4. When the chronograph is stopped press the lower left button
to reset back to zero.
SET THE TIME ZONE
the mode indicator hand to SET mode on the bottom dial.
savings time must be manually set for each city..
through all the cities. After setting, Push the lower right button
back in one click.
Hope this helps. =)
Oct 10, 2009 | Bulova Watch
Reset watch
Hi
Thanks for using FixYa. You can set the time on your accurist watch by following this procedure--
TIME SETTING--
2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position.
3. Select the time zone on the digital display by pressing the upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time.
7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour.
SET THE CALENDAR--
1. Push the bottom right hand button until the mode hand indicator points to CAL.
4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month.
5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 31, 2009 | Watches
How do you set the clock nissa versa 08
Clock set
If the clock is not displayed with the ignition
switch in the ACC or ON position, you need to
select the CLK-ON mode. Press the MENU button
repeatedly until CLK-OFF mode is displayed.
Use the TUNE/SEEK button to enable CLK-ON
mode.
1. Press the MENU button repeatedly until
CLK-ON mode appears.
2. Press the MENU button again, the time will
start flashing.
3. Press the TUNE/SEEK button
or to adjust the hour.
4. Press the MENU button again; the display
will switch to the minute adjustment mode.
5. The minutes will start flashing. Press
TUNE/SEEK button or to adjust
the minutes.
6. Press the MENU button again to exit the
clock set mode.
The display will return to the regular clock display
after 10 seconds, or press the MENU button
again to return to the regular clock display.
Resetting the time
Hold the MENU button down and then press the
TUNE/SEEK button, the time will reset as follows:
c If the displayed minutes before the reset are
in the range of :00 - :29, the hour displayed
before the reset will stay the same and the
minutes will be reset to :00.
in the range of :30 - :59, the hour displayed
before the reset will advance by one hour
and the minutes will be reset to :00.
For example, if the MENU button and the
TUNE/SEEK button are pressed while the time
displayed is between 8:00 and 8:29, the display
will be reset to 8:00. If the buttons were pressed
while the time was between 8:30 and 8:59, the
display will be reset to 9:00. At the same time the
display will return to the audio.
Nov 11, 2008 | 2008 Nissan Versa
Setting time
1) Make sure that all CDs are out.
2) Hold down SRC button until radio turns off.
3) Hold the function button down until the clock appears with the hour flashing.
4) Press the left or right arrow to select the hours/minutes.
5) Press the up or down arrow to select the time.
6) When time is chosen, press the function button again to set.
Apr 01, 2008 | Pioneer DEH-P3700MP CD Player
Casio g-shock watch
http://world.casio.com/wat/download/en/manual/
try for the manual from here.
riz.
Nov 06, 2007 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
