Question about Royal VF1000MX Shredder
Paper will not feed into machine
My Royal paper shredder vf1000 will not feed the paper in anymore, will work if you switch it into revers.... Help!
Most likely the sensor in the insertion area is not recognizing a paper when you try to insert it to be shredded.
Try to clean out the gears, and oil the grinders.
Clean around the insertion area to remove any debris from around the sensor. (Be sure to turn it off/unplug it first!).
If you can remove the shredder head/grinders from the body of the shredder box, turn it upside down and clean it that way as well.
Sometimes the little pieces of paper get clogged up inside the gears.
I got some of the dust spray with the straw...inserted the straw deep into the shredder grinder/gears and sprayed.  I got tons of stuff out.
My motor/grinder worked perfect after I did all this.
Posted on Oct 30, 2007
Royal 85x paper shredder: The shredder will start to shred but stops shortly after "grabbing" the paper. In order to get it shredding again, I have to put the machine in reverse, remove the...
Sometimes spraying shredder oil on the cutting teeth wil work.
You should shred paper with a light weight machine oil poured on the paper to keep the cutting teeth working freely.
Good luck.
P.S. If this doesn't work then just take the head off and cleanj/lubricate any bearings you find.
Mar 23, 2011 | Royal 85X Shredder
My royal 160mx shredder quit feeding paper. It runs forward & backward when the buttons are pressed but will not feed the paper.
Have a look inside where you put the paper and see if the cutting blades are turning when the machine is running...if they are NOT, then you have probably broken or stripped teeth out of a gear will have to open it up to check, then you can contact Royal at 1-800-524-0799 for parts assistance.
Nov 14, 2010 | Royal 160MX Shredder
I have a Royal VF1000MF shredder. While shredding
Try running the shredder in reverse and oiling the blades. More assistance with paper shredder oil here:
If you can't get the paper shredder back to good condition it looks like you might have to get a new paper shredder. Great place to learn about new paper shredders here:
May 24, 2010 | Royal VF1000MX Shredder
Shredder motor runs but won't shred paper. No
If the motor is running do the cutting shafts turn??? if not then unplug and open up the top to see if any gears are broken/stripped; give Royal a call at 1-800-524-0799 for parts and prices once you've located the problem.
Oct 23, 2009 | Royal VF1000MX Shredder
Royal 9 x cross cut shredder wont go through even two pages thick
Put some shredder oil on the paper you are shreding...shred a number of sheets with oil on them so that the oil gets down into the cutting shafts/teeth.
Jan 12, 2009 | Royal Office Equipment & Supplies
Royal CIA 12X Shredder Problem
If your machine has an electronic paper feed sensor try cleaning the sensor with a qtip dipped in rubbing alchohol.
Mar 01, 2008 | Royal CIA 12X Shredder
Paper not going down
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Dec 26, 2007 | Royal Orca ASF5000X Shredder
Paper shredder vf1000
I feel for you too, I have the same problem, You have to order the gear at
Dec 23, 2007 | Royal VF1000MX Shredder
Royal VF1000MX Shredder Logo
335 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
