Try to be a little more vague! Model? Age of steamer? Rate of use?...Try a couple of drops of vinegar in with the water you use to fill your steam mop. The heating element that heats the water is probably oxidized, especially if you use tap water to fill it. You should only use distilled water in these mops. Some lower end steam mops have a handle that compresses, as you push the mop forward, which essentially makes the mop steam more, the more you "pump" the handle. Hope this helps!
It may be mineral deposits. Empty reservoir of water, add 1/2 cup of CLR. Let sit 1 hour. Take mop outside with a mop head on but not the cloth padding. Plug it in and start pumping the handle to prime it. I used cardboard to do this on to cushion the mop and soak up moisture. Keep pumping handle until the mineral deposits clear and full steam is coming out. When I was done, I unplugged the mop, dumped out remaining CLR, and rinsed out mop reservoir with water. Please add fresh water, plug in and steam out rest of CLR out of tube leading to mop head. Otherwise your mop will still issue out CLR steam. As always, be careful to unplug and let the unit cool down before adding or removing CLR, water or mop head. Steam can cause serious burns.
