Question about RCA HD52W56 52" Rear Projection HDTV
Programming digital channels
Have a 52" RCA HDTV, hooked to cable from the wall, no cable box, plugged into the analog (bottom) plug on the back of the tv.  We are unable to program any digital channels, which we know are available from our cable company (Mediacom).
Have followed all directions from the manual from the tv.  Any suggestions that we might be missing when programming the channels?
  • 112 Answers
The problem is not with your TV. You need a digital box to unscramble the channels.
Posted on Dec 20, 2007
IS RCA DIGITAL TV CONVERTER BOX DTA880 COMPATIBLE WITH ANALOG MAGNAVOX TV COMBO MWC24T5B?
they sell those cable adapters almost every where tv antennas & cables are sold even home improvement stores like home depot and Menards
Sep 22, 2015 | RCA Televison & Video
How to hook up an old RCA 14 inch tv to DVD
Easy. All you have to do is to make sure that the DVD player is old the older types that have RCA connectors at the back of the DVD. Latest DVD may have RCA connections but I am not sure if it can send digital signal directly to the analog TV. Try this and see what happens. if your TV is old and does not have Component Video (Red/Green/Blue) RCA sockets (input) but has standard Pal/NTSC sockets (Yellow/Red/Black) hook up the yellow, red and black plugs into a DVD (out) RCA sockets of same colour, then hook up the other end of the cable in the (in) RCA sockets at the rear of the TV.
If it works, then all is well. If it doesn't work, then you have to hook up the cable from the DVD to the (input) RCA sockets of a Set Top Box, so that the Set Top Box will convert the signals for the analog TV. Just pay attention to the inputs and outputs at the rear of them.
On your DVD - plug the RCA cable to the (OUTPUT) RCA sockets. On the Set Top Box - plug the connectors in the (IN) RCA sockets and then use another cable connected to the OUT RCA's of the Set Top Box, then connect the other connectors to the (IN) of the TV RCA sockets. Hopefully you get the picture on what I mean.
Sep 01, 2014 | Televison & Video
Why all my cables channels not working
if you are using coax cable to conn cable box to tv, be sure to use the analog ant conn on back of tv, and there is a switch on the back of the tv for selecting channel 3 or 4, for cable box use. be sure to turn tv to the same channel the switch is selected to, and always use the cable box to change channels/ programs, not the tv channel selector.
Feb 26, 2013 | RCA R52WM24 52" HDTV Projection Television
Does the RCA TV model D52W20 have a digital tuner? or will I need a cable box to watch TV? At our location they just switched the signal. we just had a tube TV with the cable line in the back and up till...
Greetings Pete - No, your display is what is called HDTV ready, meaning it needs a separate tuner AKA set top box.
You need to get the cable box, plug in the component video cables into your TV (usually provided) and plug in audio cables and you're viewing HDTV. See below:
Happy Viewing!
Regards,
Mikeywaf
May 17, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
How do you connect the cable to the tv? I have a dvr box but dont know where the connection on the tv is?
Cable from box to t.v , from antenna to box . If you have a hdmi cable plug into the back of the box, and plug into the hdmi input on the back or side of your t.v
Jan 17, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
How do you hook up to dish network? there is no spot on the back of the tv to hook up the regular tv cord coming out from the cable box.
At the bottom right of this model there should be a connector labelled Antenna/Cable - if not there, use the ones labelled Composite Inputs and connect the yellow red and white cables fom the output of the satellite box there. (you'll need a the a/v cables)
Oct 05, 2009 | RCA D52W23 52" HDTV CRT TV
Vcr hooked up, no audio
From the VCR to the tv if you have RCA cables its kind of hit and miss where the audio cord goes. Only one of the jacks are for sound but it has to be plugged in to the right input. Audio is usually the white one. Just keep touching it to inputs until you hear sound start to come out of the speakers. Hope it helps.
Jun 27, 2009 | Insignia Digital-to-Analog Converter for...
Hd channels not showing
Your tv has a input named COMPONENT to make work this input you need three RCA conectors (RED GREEN BLUE) plus two audio RCA Conectors red and white. If you have another set that can be plug in in this input and that set (dvd recorder, in ex.) has a digital tuner then you got it, But the Magic about the decoder box is that only cost 40.00 +- dllrs and send the signal to your antenna connector or RCA analog conector. Good luck!
Mar 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
HDTV MODEL HD52WS9YX39 SERAL NUMBER 6116CNO13
please recheck your model# it should read HD52W59YX39 if this is the correct model the part # is 271850 cost $166.99
changing this part will cause major alignment
the part can be replaced - the RF part # is 215543 for $4.39 or the tuner can be changed part # 268904 cost $30.39
on another note if you are using a cable box or sat box there is no need to repair the rf hooke the tv up with rca plugs
https://www.vancebaldwin.com
thanks
scott
Jun 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W56 52" Rear Projection HDTV Logo
239 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
