Lance alignment is disturbed
hi,if you are a tecnition then open yor camera and remove the lence assembly,then remove the motor and clean the lence unit properly ,and check that smothness between lence beralls, it must be rolling smothly ,and roll the moter by using adapter of 5 volts ,roll motor both side ,after that fix it properly ,now you can check it by put suply on motor and see what has be done,if lence responce smothly in and out then fix it with camera,and see the magic
