RCA HD52W58 52" TV Logo
Posted on Jun 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RCA HD52W58 Picture not working / Sparking in back.
We have an RCA Model # HD52W58. We came home after camping over the weekend and the picture was not working on the TV. The volume works but the picture does not. After a few seconds, the green power button would flash and the TV shuts off. Looking through the grate in the back of the TV while turning the power on, we noticed some sparking in the back at the bottom near the flat circuit board. Any ideas of what it would take to fix this problem?
  • chmiller1977 Jun 12, 2009
    I took of the back panel and I found a capacitor (I think that is what it is called) at the front of the circuit board that was burnt and split in half? I can't get the complete number above it.
    Is this something I can replace or do I need the whole board that it was attached to?? And do you have any idea what I might be looking at cost-wise?
Darial Jr Lasaria
Level 3:
  • Master 379 Answers
  • Posted on Jun 11, 2009
Darial Jr Lasaria
Master
Level 3:
Answers
379
Questions
0
Helped
120714
Points
1040
Maybe there is a lizard inside, open the back cover then remove the PCB. re solder the damaged area and clean it with an electronic spray cleaner. check for cold solder component leads and re solder it.
1helpful
1helpful
My RCA Model number HD52W59 has color distortion and double image and sunk picture in the middle. Is there any way of fixing this problem. This tv is a projection TV
Yes.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be change to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
1helpful
HOW CAN I GET THE HD PICTURE CLEARER?
Hi there.
To answer your question;
Since you said that you can`t use hdmi/dvi your next best choice would be component video input(3 rca cables).
Your next choice would be svideo in.
It may improve your picture over standard cable in.
hope this help. Happy holiday
Where is the convergance amp?
Accros the top of the chassi.conv power supply is to the left
Green light stays on but no picture
This is very hard to know the problem. A lot more info is needed to know about voltages on the inside of the tv. I would say to take it to a repair man.
Problem with rca hd52w58 52" tv
This can be a green crt or green driver pcb problem. You can try and unplug the tv for 30 min. and plug it back in and turn it on, but the problem will most likly still be there. A repair shop will need to fix it from there.
RCA Home Theater (Model #P46924) No Picture, just sound
Sounds like a possible solder issue with the vertical output IC. Try resoldering the Vertical output IC connections
2answers
Powers on and then right back off
Try and clean the two filters on the tv this should be the first thing to do.
3d picture
Bad convergance amp ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
1helpful
Rca Hd52w58 electrical short
Just replace it... it is called the High Voltage Splitter. One red wire is the high voltage input from the flyback (high voltage) transformer, 3 red wires are the high voltage outputs that go to the 3 picture tubes and the red wire by itself is the focus wire going to the focus block. Does your splitter have a small PC board on the side of it? What is the exact model or chassis number of your set? With that info I can give you the RCA part number of the splitter which makes ordering it much easier.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
