Dish network hd monitor
Tv
 i have a dish network hd monitor tv model: HD34-310. when i turn it on the green light comes on but i have no sound or picture
  • 2 more comments
  • jffry May 15, 2008
    I have the same problem. When I turn the tv on it clicks and buzzes like it is going to turn on, but it doesn't. After a few seconds the light goes out and there is no picture. It has been doing this off and on for a week now.
  • Donna in AZ May 22, 2008
    I am having the same problem. I have called several places and no one has heard of this TV Brand. Is there a solution to the problem? Is there a part I can purchase to fix the problem? Is there any information I can provide to a repair person so they don't charge me an arm and leg to fix the TV. Thanks, Donna in Arizona
  • Anonymous Jul 04, 2008
    I have the same problem. I have been able to get the tv to turn on twice by pushing the menu button and then a series of channel then volume, but I forgot the series. Oh yea - once on leave on. I unfortunatley shut it off on accident again. Todd
  • Anonymous Dec 24, 2008
    Yes me too. I guess I will send it to the scrap heap.
    New Friend:
HI GUYS.. I'M A LITTLE LATE, BUT I HAVE YOUR ANSWERS! UNFORTUNATELY, IT'S NOT REALLY GOOD NEWS :(
GO HERE: http://www.satelliteguys.us/threads/142951-Hd34-310
Posted on Jan 06, 2013
MY 34-300 IS A RCA
Posted on Nov 01, 2008
I did some research and found that it is a small part on the television that has gone bad. The problem is that it is sodered to the circuit board. So, in order to fix it I would have to purchase a new circuit board and swap the whole thing out. I have had no luck find a circuit board that matches the one I would need because no one knows who the manufacturer is.
Posted on Sep 19, 2008
Oh man this is happening to me also! i am having a helluva time! the damn thing is only 3 years old!
I have same problem. Try pushing the menu button and then a series of channel and volume buttons. I fixed mine twice. Once the tv is on, leave on always. I accidentally shut mine down a third time.
Damn the luck.
Posted on Jul 04, 2008
Did you get a resolution to your problem? I am having the same situation.
Posted on May 15, 2008
SOURCE:
Help me, dish network hd monitor,model 34-310. made in 2004. wont turn on,on button blinks and attempts to,turn on but screen remains blank. tries three times and blinks a green light. no picture,no sound....
It is the right age for failure---IF you are able look inside at the power supply for bad caps---I will attach photos of what to look for.
The three tries is what is called a three strikes and you are out (no joke)----the unit has built into it (many do) a feature where it will try 3 times to make it up and on and if fails shuts down or stops trying.
Dec 07, 2012 | Computers & Internet
Upgraded to Hd and tv started messing up. Double images for first 10 minutes and sometimes tv picture goes off and lines up and down.
Your HDTV is capable of up to 1080P resolution. SDTV (standard def) signals are 480i; EDTV (enhanced def) is 480P; HDTV are 720P, (there is no 720i) 1080i and 1080P. Generally, those modes ending in "P" look better than those ending in "i". 1080i is the highest possible for broadcast TV, but BluRay disks and Directv have 1080P display capabilities.
The double picture you're describing sounds like the TV is set to display only standard or enhanced def signals while the Dish Network box is supplying it with HD signals. You should locate the control for the TV's resolution and make sure it is set to "1080P" and then set the output of your Dish Network set top box to the highest output it offers. Do the same for your BluRay player and any other devices, too.
Once set correctly, you should have a great picture once again. I hope this helps & good luck!
Sep 04, 2012 | Sony KDL-40XBR4 40 in. LCD HDTV
I own an insignia 42"
The TV resolution is set by the video sources, not at the TV, in this case, your Dish network box is the one that is sending out 480p so the TV will display what it is being fed with.
What does Dish TV say aboyt this problem? How about the setup menu on the Dish network box?
Your TV works the same as your PC monitor, except that your monitor does not have a tuner, you adjust the resolution at the PC not at the monitor. 480p in = 480p display.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Jan 31, 2011 | Televison & Video
Unhooked all lines in back of tv cant remember to rehook up have2
granmabj,
There are common connections to each receiver but there are unique connections also depending on the receiver. Solo receivers have a coax cable coming from the Dish outside connected to Satellite In. Duo receivers and DVR HD receivers have the coax cable that comes from the dish outside that connects to Satellite 1 and Satellite 2 using a splitter. There is also a cable (coax, RCA (yellow, white, red) or component (green, blue, red - video, white, red - audio) or an HDMI if HD) connected from the receiver to the TV 1. For a duo receiver TV 2 may be backfed on the cable coming from the dish outside using diplexers. This may sound confusing but you can call 1-800-333-3474 for assistance.
Ray Calo
DISH Network
Jul 23, 2010 | DISH Network DVR-625 DTV Receiver /...
Toshiba CN36X81 television.. NO Sound... Great Picture. Using the TV2 output of a DISH Network HD receiver... TV2 output is std def, coax output. Using a different TV I get picture and sound... but not...
IF coming in via, the "Dish" networked receiver, please check that this volume is turned way up, on the TV. and then control the the Volume, with the Dish Remote, often this is a problem, as one is turned down, and the other cannot turn that up, simply try syncing the Volume controls, UP on TV, control the Audio with dish remote. thats all i can think of. Check by feeding a signal IN from an AV, source, ie: Yellow, Video, & Red& White, Audio. Turn TV UP and check, IF it responds to this all is well. If NOT then you do indeed have a fault, with the TV.
Mar 27, 2010 | Toshiba CN36X81 TV
Dish Network HD40-310 Monitor wont work
Check the flyback transformer. I have the same set and have significant sizzling and arching from the back of the set.
Jan 01, 2010 | Televison & Video
Magnavox 52 inch HD Tv connected to a Dish Network HD Satellite Box. If you watch a channel with HD programming and then tune to a analog channel there is no sound. The tv has to be turned off and back...
have you tryed to go to setting and letting it yout tv know that you want sound onto the hd channels.? if you have any more problems joust contact you coustmer service for dish network. problalby your tv is not compatible and you need an hd receiver. i have dish network myself and just upgraded my receive to hd.
best of luck- JD
Nov 18, 2009 | Philips Televison & Video
I purchased the hdtv model DP32648 at walmart, I hooked it up, it is on and working , But some stupid guy told me I needed a cable called HDMI, OK So I have it But I have Dish Network, their is no place to...
ya dish network reg box isnt hd ok u need call dish get hdtv box then u can use hdmi cable to get hi end picture ok for now use cox cable like u do to u can upgrade dish hd sumday k
Oct 15, 2008 | Televison & Video
I have picture by no sound. It's on video...DP42647 model We use dish network
I am going to assume this is a self install meaning you just got a new tv. If you have an HD receiver connected with red/blue/green wires ensure that you also use a set of red/white from the same TV output on receiver to the same audio input on the TV that you have the other wires ran to as the RED/BLUE/GREEN only carry a video signal. Some poor quality HDMI cables will also require the same red/white wires to gain audio as they do not always function properly. Other than that I can think of no other reason you should not be receiving audio other than internal speaker in tv being turned off. This usually is true when a surround sound is in use but the dish receiver was not integrated into the surround but the TV itself. I hope this is of some assistance to you. Thanks for using Fix Ya and if I can be of anymore assistance please let me know.
Oct 08, 2008 | Televison & Video
Dish Network HD Monitor HD 40-300
I have a Dish Network HD40-310 Monitor. When you turn power on the green power light comes on, then tv makes funny noise, then goes off again without producing any picture. Any ideas how to fix?
Aug 02, 2008 | RCA Televison & Video
Televison & Video Logo
836 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
