Question about Kenmore 74602 Gas Dryer
Kenmore dryer won't start
Kenmore model 77832 gas dryer won't start. It was working fine last night but my wife threw a load of clothes in this morning and it just won't go. When I push the start button it makes a buzzing sound like a relay isn't working. I bought it used and I have no wiring diagram. Where do I start?
  • 2 more comments
  • sthol Nov 22, 2007
    dryer won't start , when i hit the start button the relay justs clicks
  • MikeDryer Apr 22, 2008
    Kenmore 70 series gas dryer) I tested the thermal fuse it's OK. The door switch is OK too. I pushed the start & turned the timer dial and it started once and ran a cycle, but now that wont work either! The timer counts down. When I push the starter button, it makes a noise as if it wants to start, but does not. Can you help?
  • Anonymous Apr 30, 2008
    Ihave a model 87870100 door switch is good temp select ok start switch ok timer appears to work but it will not start.
  • furreness May 09, 2009
    Kenmore Electric Dryer
    My dryer won't start. I disconnected the switch and now I hear the motor wanted to start. Can I fix the switch, or do I have to buy a new one? Switch 337351
  • 90 Answers
Bad thermal fuse
Posted on Jan 05, 2008
Kenmore model# 96281100 elect. dryer
Jimbo, this dryer uses a cyling thermostat to turn the heater on and off. If your vent is pinched or clogged, or the vent to the outside is clogged, you are going to have long dry times and damp clothes. Try doing a load with the vent disconnected from the back of the dryer. If everything turns out ok, then it's a venting issue. Catriver
Sep 14, 2007 | Kenmore 63942 Dryer
Gas dryer will heat sometimes and not heat other times kenmore model 72802
sounds like bad gas coils,you have to send the whole model number,it will start with 110. or similar,if the bottom panel comes off,remove it,start the dryer, or in the front panel down near the bottom pop off the cover and look in,if the flame lights and then after 10 to 20 minutes the flame doesn't light you have bad gas coils.when the coils are starting to fail they will work correctly until they heat up and then they won't work until they cool down,the coils are what opens the gas valve.the coils are on top of the gas valve,remove the two phillips screws,pull off the cover,remove the wires from the coils and install the new coils,put it back together and you'll be fine,also while you're in there,get a shop vac and vac out the cabinet,stick it on blow and blow all the lint off of the motor and out of the gas tube,then clean out the duct that the lint filter slides into.if your vent line is a long run from the back of the dryer to the outside,i use a leaf blower remove the vent line from the back of the dryer and blow all the lint outside out of the line,do this once a year,you won't have any fires,your clothes will dry on time and your motor and parts will last longer
Oct 28, 2011 | Kenmore 72802 Gas Dryer
I have a Kenmore gas dryer Model 74812200. It is no longer heating up. When I turn it on, I hear a clicking sound for about 30 seconds then it goes off. Then about a minute later I hear the clicking sound...
You would not hear the click if the ignitor was bad. It won't click until the flame sensor get heated up by the ignitor. So that tells me the thermal fuse ain't melted. I would say them coils on the gas valve are the problem. themobilian_2943.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 30, 2011 | Kenmore 74812 Gas Dryer
The rinse cycle does not work, but everything else does
I don't know if the problem is solved but last night we ran the washer without any clothes in it and everything seemed to work fine. My wife was able to run a load of laundry and it seemed to work. I hope it was just too much clothes the first time it stopped or the washer was just acting up. Either way, I had nothing to do with the fix. Sorry I couldn't be any more help. Thank you for the link to assistance plan, it might come in handy in the future.
Thanks again,
Sandro Micocci
Mar 30, 2009 | Kenmore Washing Machines
Kenmore Gas Extra Capacity heats only on timer,not Fabric Master.
get some windex and clean the sensor strip located behind the filter ousing similar to this picture. Their might be something on it that is interfering with its moisture sensing ability. Check out my youtube channel about section for a link to a free dervice manual for you model. Thanks
Dan Webster
Jun 18, 2017 | Kenmore 73952 Gas Dryer
Kenmore 600 Series gas dryer
trigger broken dryer will not turn on. I need a replacement. Where can I buy this part.
Nov 02, 2008 | Dryers
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
Kenmore 74602 Gas Dryer Logo
1,919 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
