Microphone des not work
There are two items you'll need to check. First, when you boot your system press the Delete key to enter the bios. Open the Advanced tab.
Make sue your Audio is set to [Enabled].
For windows XP operating systems check within windows Device manager. Click the start button, open control panel. Double left click on the "System" icon to open. System properties window will open. Click on the Hardware tab than click on the "Device Manager" button. Scroll down through the icons until you come to: Sound, video and game controllers. If there is a problem with the driver you will see something like. Unknown pci controller or simple pci controller. If you do not see something either of these than there is nothing wrong with your driver software. Make sure you setup your microphone. Open the windows "Control panel". Than open, "Sound and Audio Device". Click on the Audio Tab. Under, "Sound playback" the Default device should read as; Realtek AC97 Audio. Now click on the Voice Tab. Under "Voice playback" the Default device should read as; Realtek AC97 Audio. Lastly, you need to click the "Test hardware" button. Follow the instruction from windows. It wouldn't hurt to check windows for updates. If you still do not have use of the microphone than the intergraded sound controller is defective. This can’t be repaired. You can disable the intergraded sound controller in the bios. Than buy a PCI sound card and add it into an opened PCI port.
Hope you find this helpful.
Mike
