I recently moved, upon setting the tv up in my new place i noticed a small bit of damage to the channel/volume pannel on the tv.i tried the power button with no result i located my remote but still no results
Contact any service technician or the authorized service center for Emerson. Gopakumar Gopalan Google
SOURCE: volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
SOURCE: Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
