Question about Frigidaire GLGQ642A Gas Dryer
Running but not heating up to dry
I am currently having a problem with my...I am currently having a problem with my Frigidaire GLGQ642AS1 Dryer. It is running but it is not heating up to dry the clothes.
  • jimv2 Nov 20, 2007
    I have repalced the ignitor and cleaned all of the lint from the interior of the unit. I have also cleaned the lint filter with soap and water. The unit runs but will not light off, no heat !
Does the Ignitor heat up? If not, the timer might not be telling the gas system to start.
If the ignitor is heating up, and there is no gas, it may be a wiring problem or a gas valve problem. Need more information to solve.
Next step if ignitor is working, is to check to see if voltage is being sent to the gas valve.
Posted on Feb 18, 2009
I have a Frigidaire Dryer Model#FEQ1442ES0
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Frigidaire Electric Dryer
My dryer still runs but it's not drying. It's also not heating. Can this be fixed by replacing a part?
yes, here is a site that can help, Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 28, 2010 | Frigidaire FER211A Electric Dryer
Frigidaire FEQ1442ES Electric Dryer not producing heat. Quits running part way through cycle... Lights flashing green.. Clothes never get dry. Code E95
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a Free answer, Please rate me.
Oct 10, 2010 | Frigidaire FEQ1442ES Electric Dryer
Dryer is not getting as hot taking longer to dry clothes.FRIGIDAIRE MODEL GLER341AS2.
If your dryer is STILL heating, but your dryer is showing signs of heavy condensation or longer dry times, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. As the dryer exhausts, moisture from your clothing is circulated with the warm air. If you have any restrictions in the exhaust system, the moisture will collect inside the ducting and drum. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer in a clogged state, or having improper air flow, will not dry efficiently and will cause the heating circuits to overheat. Eventually, this can lead to component failures and is the source of many fire hazards.
If you do determine you have an internal component problem, the next link can give you some helpful advice on how to troubleshoot a dryer with a no heat problem: http://www.fixya.com/support/r3574266-thorough_dryer_advice http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat If you have any questions, please post back and let me know. I hope you find this information helpful.
Sep 15, 2010 | Frigidaire GLER341A Electric Dryer
Have a frigidaire "gallery" series stackable washer/dryer, the heating element initially turns on when the dryer starts. you can see the element light up and feel heat but after a minute of run time the...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Frigidaire Dryers
My Frigidaire dryer has an error code of AD and is taking forever to dry our cloths. Please help.?
Hi
Thanks for using FixYa. Error code AD means air/auto dry. This type of dryer has no thermo fuse which is a fuse like part that tends to break disengaging the heating element, there for the dryer has a busted heating element, you’ll need to replace it then it should be good to go. Normally runs parts and labor about 150. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 28, 2010 | Frigidaire Dryers
I am currently having a problem with my Kenmore Dryer. It is running but it is not heating up to dry the clothes. Someone told me to take the back off and check the heating element but I can't find the...
I would check your vent if I were you disconnect the vent and run the dryer to see if it works better. also clear the vent line. good luck
Jan 10, 2009 | Dryers
Frigidaire dryer heats but clothes not drying
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
Nov 23, 2008 | Frigidaire GLER642A Electric Dryer
Frigidaire GLGQ642A Gas Dryer Logo
214 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
