Question about Durabrand DB1200 CD Player
Power, but no sound!
I have an 88 T-bird Turbo Coupe with a factory Graphic Equalizer. When the factory tape deck is installed the Equalizer gets power and it all works fine. When I install the CD player the CD player gets power, but the Equalizer doesn't. In this case, I don't get any sound. How do I get sound and make the equalizer work? (Is this because the factory tape player didn't have bass and treble and the CD player does?)
You might not be hooking the wires up just right, I had the same problem with mine
Posted on Dec 19, 2007
On a kenwood KR597 reciever, where do i hook up my KE597 graphics equalizer. Also must i remove my DP-R797 cd player to hook up my Maeantz PMD520 Cassette deck? Finally divorced
If you only have one set of tape in/out connectors, then hooking up two tape decks and an equalizer is going to be difficult. You could hook the "tape out" to one tape deck, that tape's output to the second tape, and the second tape's out to the equalizer, connecting the output of the eq back to your receiver....
Nov 01, 2014 | Audio Players & Recorders
Can i use a graphic equalizer with a yamaha as-500
My Yamaha Equalizer is Model GE-30. Review the manual for this unit and on page 3 you will see the connection procedure "Line Out" on the equalizer to "tape deck in" on the amplifier. In the case of the A-S500 user manuaI on page 5, I used the "line 3 " also identified as "tape deck" to connect the equalizer.
The front control(s) from page 2 on the A-S500 manual are then set :
Control(5) input selector set to Line 3 (Graphic Equalizer)
Control(8) REC OUT selector to CD (for CD), line1 (my blu-ray player, or tuner (my DVR/tv)
The only thing I lose is "PURE DIRECT" does not fuction if the equalizer is on, otherwise;
I simply set Control(5) input selector swith to the desired input source, the equalizer no longer
functions and "PURE DIRECT" can now be used.
The rest of the tonal controls for bass, treble, balance, and loudness work as they should.
Jan 29, 2013 | Yamaha AS500 Amplifier
I cnt find away to instal my stereo graphic
'Organizer'?
It takes two to tango.Install to what? No manuals?
Any analog audio processor or tape deck traditionally goes into a Tape Monitor Loop on a receiver or preamp. Be advised that the use of any Tape/Processor Loop will disable digital audio sources on a digital receiver/preamp.
Web search that term. Then add 'equalizer' to it. They all attach in the same basic way.
Aug 05, 2011 | Technics SH-GE50 Home Equalizer
Where the fuse box to a 88 ford thunder bird 5.0 liter
The fuse panel is located underneath the dash, to the left of the steering column, next to the emergency brake pedal. You need to remove the under-dash insulation to access some parts of the fuse panel.
If it doesn't have a diagram inside the box, here's one I found online: http://www.coolcats.net/tech/reference/images/fusepanel.jpg
1 15A Lt. Blue Stop Lamps, Hazard Warning Lamps, Speed Control, Cornering Lamp Relays 2 6A - CB - Windshield Wiper/Washer Pump 3
Spare - Not Used 4 15A Lt. Blue Taillamps, Parking Lamps, Side Marker Lamps, Instrument Cluster Illumination, License Lamps, A/C and Heater Illumination, Radio Illumination, Digital Clock Illumination, Autolamp Relay 5 15A Lt. Blue Turn Signal Lamps, Electronic Day/Night Mirror, Lighted Vanity Mirrors *, Backup Lamps, Illuminated Entry, Keyless Entry, Cornering Lamps 6 20A Yellow Rear Defrost Timer, Chime, Back-Up Lamps, Cornering Lamps, Rear Reading Lamps, Trunklid Release, Digital Clock Display, Illuminated Entry, Anti-Theft Module, Turbo Buzzer 7 15A Lt. Blue Fog Lamps (Turbo Only) 8 15A Lt. Blue Courtesy Lamps, Key Warning Buzzer, Illuminated Entry Module, Glove Box Lamp, Door Lock Relays, Radio Memory, Cluster Memory, Outside Mirrors, Tripminder Module, Analog Clock, Anti-Theft Relay 9 30A Lt. Green A/C Heater Blower Motor 10 20A - CB - Horn, Cigar Lighter, Fuel Filler Door, Flash-to-Pass, Speed Control 11 20A Yellow Radio, Tape Player, Premium Sound Amp, Power Antenna, Graphic Equalizer 12 20A - CB - Power Seats, Power Locks, Keyless Entry 13 5A Tan Instrument Cluster Illumination, Radio, Climate Control 14 20A - CB - Power Windows, Power Moonroof 15 10A Red Taillamps, Rear Side Markers, License Lamps, Electoluminescent Coach Lamps 16 4A Yellow Electronic ATC 17 15A Lt. Blue Electronic Cluster, Tripminder Display, Fuel Gauge (non-electronic cluster), A/C Clutch, Speed Control Module, Graphic Warning Display Module, Electronic Blower Speed Controller 18 10A Red Warning Indicator Lamps, Autolamp System, Throttle Position Sensor, Low Fuel Module, Dual Timer Chime, Tachometer, Washer Fluid Level Indicator
May 20, 2011 | 1988 Ford Thunderbird
Aai have the following AKAI Audio Stereo System and no Idea how to connect them. Please help Akai Model AP-D210 turntable Akai model CS-F14 Stereo cassette deck Akai model AT-K110 Fm Am Tuner Akai...
In general, outs to ins.
If nothing else, get the manuals for the preamp and the EQ. You'll probably have to pay for them.
Google it.
Akai PR-A04 preamplifier << This is the control center and where everything comes together.
Akai AP-D210 turntable (ONLY to jacks that say "PHONO"
Akai EA-G40 Stereo Graphic Equalizer (in the Tape 1 Out/In set)
Akai CS-F14 Stereo cassette deck (in the Tape Out/In set of the EQUALIZER) *
Akai AT-K110 Fm Am Tuner (to the Tuner inputs)
Akai DT-100 Audio Tuner (to the Aux inputs)
Akai PA-W04 Amplfier (to the amp outputs)
* This will allow you to Equalize the Tape on the Record or the Playback side.
Read some audio magazines or websites. Get to understand Tape Monitor Loops.
Don't use excessive EQ.
Mar 17, 2011 | Akai Audio Players & Recorders
I need a hook up digram fof an optimus model 31-2025 stereo equalizer
http://support.radioshack.com/support_audio/doc48/48943.htm
Ten-Band Stereo Frequency
Equalizer (310-2025) Connections Faxback Doc. # 48943
Follow these steps to connect the equalizer to your audio system.
CAUTIONS: Use only shielded audio cable with RCA-type connectors (not
supplied). This type of cable is available at your local
RadioShack store.
Before you connect the equalizer, turn off all components in
your audio system and unplug their power cords.
Before you plug in the equalizer's power cord, complete all
connections and be sure the equalizer's POWER button is out.
1. To connect the equalizer to your receiver, connect the receiver's TAPE
OUT jacks to the equalizer's MAIN IN jacks.
Then, connect the equalizer's MAIN OUT jacks to your receiver's TAPE
IN or TAPE MONITOR jacks.
2. You can connect a tape deck to each set of tape jacks (TAPE 1 and TAPE
2) on the back of the equalizer.
To connect each tape deck, connect the equalizer's TAPE OUT jacks to
the tape deck's in jacks. Then, connect the tape deck's out jacks to
the equalizer's TAPE IN jacks.
3. Plug the equalizer's power cord into your receiver's switched power
outlet or any standard AC outlet.
WARNING: The equalizer's power cord has a polarized plug. To prevent
electric shock, do not use an extension cord or other
receptacle unless you can fully and easily insert the plug's
blades.
4. Connect the power cords of all other components.
(wr 08/04/98)
Feb 24, 2010 | Audio Players & Recorders
Forward and reverse not working driver front seat 88 t-bird turbo coupe
if the other motor controls are working it sounds like a bad switch
Sep 03, 2009 | 1988 Ford Thunderbird
Kenwood tuner/graphic equalizer c-h6
sound output section trouble.can you remoove and shall we start rectifing the problem.
nuwan
Dec 04, 2008 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Graphic equalizer
In general all equalizers, being designed to be in a Tape Monitor loop, have the option to Equalize either the Source or the Tape or nothing. Check for that control and toggle it. My old ADC SS-525X has pushbuttons whose settings (Tape/Source) are not easily determined. I always have to play around with it to know which is selected.
I'm betting your EQ is processing the program that would head out to an attached tape deck.
Nov 14, 2007 | Onkyo TX-8222 Receiver
Durabrand DB1200 CD Player Logo
143 people viewed this question
Top Durabrand Car Audio & Video Experts
matt martin
matt martin
Are you a Durabrand Car Audio and Video Expert? Answer questions, earn points and help others
