Wifi will not turn on in the options will just ask if i want to reset to factory settings. help
SOURCE: how to reset to the factory settings?
turn camera on, turn upper dial to setup, have the display on, use the up/down arrows on the back of the camera to click to RESET ALL, use the side arrow to to click to the reset box, either NO or RESET.
SOURCE: coolpixS51 camera stuck on set time and date
Not 100% sure about this model, but most have another battery in the camera for the clock functions. That battery could be low.
Try looking in the manual for the clock battery and pull that and replace it. See if that helps.
SOURCE: Flash has stopped working on my Nikon D40
There's a common problem in the flash arm. I found this link that shows a simple repair. If you use this and make the repair yourself, understand that you will void your warranty if you have one. Also, do not touch the bulb as you'll get oil on it, and don't touch the solder points on the wiring, you'll get zapped. http://www.vimeo.com/3141400
SOURCE: I lost control of my camera d40x
as i already mention I already used both methods of reseting
SOURCE: Reset to factory setting
Remove the battery for 20 mins. Then replace the battery and go to the camera's Menu setting and set the date & time.
