Question about Panasonic SC-HT730 System
No sound at all in any mode
I tried to connect two additional speakers for the exterior of the house using an A-B box. It didn't work.
I then put the system back together as it was beforeĀ using the manual Operating Instructions. No sound.
I disconnected and reconnected everything again but still have no sound.
    Problem Solver:
  • 10 Answers
If you get a F61 error when the unit is powered on then the output ic is bad.Subwoofer has the power amp built into it.You may have damaged the IC with a mixup in the +/- speaker hookup and the common ground connection in the A/B box.Seems your subwoofer will need service.
Posted on Apr 05, 2008
I am at my moms house she has a ?levia Tv it is connected to the Direct TV cable box in the DVI mode we have a great picture on all the channels but no sound can someone please help me please
The DVI mode may not carry audio information. The HDMI connection has audio information in the cable with the video. S-video and RGB do not have the audio.
If this is the case than a pair of Red/White audio wires that have RCA connectors on either end need to connect between the Direct TV box and TV. If HDMI is available you would not need to use the additional cables.
If you end up with the additional audio cables you may need to adjust the settings of the TV using the menu feature on the remote.
Nov 28, 2015 | Televison & Video
I am down my mom house She gas a ?levia Tv I connected it to a DirecTV cable box to get a picture it is in DVI MODE Picture is very good BUT no Sound can you please help us
DVI interface doesn't carry audio like HDMI does. If you are using a DVI interface cable, you need to use additional audio cables to get sound.
I have a magnavox 32mf605w/17 flat screen TV my sound us not working is there any way to hook up external speakers to it?
Hi Lisa,
Many a times the speakers in flat panel TVs go bad. You either change the speakers or hook your tv to some sound system like a home theater or some music system in your house. There is AV out sockets at the back of the TV. Out of the three ie. yellow, red and white use red and white to connect to the music system, put the system on auxiliary mode and enjoy the sound of your tv. Good luck.
Apr 08, 2015 | Magnavox Televison & Video
I have a 2007 trailblazer. The rear speakers didn't work and some of the head unit lights didn't work. I replaced the headed unit and that didn't fix it. I then replaced both speakers and one...
Put new wireing in going to both back speakers, Factory wireing is verry thin end it breaks with age. Change it over to at least 16 guage speaker wire or 12 guage, Your system will sound a lot better.
Oct 26, 2012 | Cars & Trucks
After unplugging my computer for a week, the sound on my CLT 190 LX computer monitor didn't work, even though I tried several sound sources from online as well as MP3s on my computer. The headphone...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
May 10, 2011 | Computers & Internet
Onkyo HT S3300 center, left front and rear speaker not working.
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Apr 28, 2011 | Audio Players & Recorders
No sound from any source from speakers
check your connections again and ensure you have the audio going out. With many tv's you need to change a setting in the menu, double check that as well.
May 05, 2009 | Denon AVR-687
No sound from speakers on a dell dimension 3000
click volume bottom right desck top.
open volume control and make sure nothing is checked in the mute boxes.
Dec 04, 2008 | Manhattan 1100 Computer Speakers
Dialog track not playing for a 5.1 DVD
swap the audio jacks and then try.
Dec 03, 2008 | Onkyo TX-SR705 Receiver
Bose amplifier does not work with a 6 speaker selector
your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
Mar 18, 2007 | Bose Lifestyle SA-3 2-Channel Amplifier
Panasonic SC-HT730 System Logo
80 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
