Question about Emerson CKS3029 Clock Radio
Time Zone Help
Can someone assist me in making sure that I have the correct time zone checked.  I live in AZ (MST) I want to make sure that my clock is on the correct time zone.  I do own the CKS3028 - but the clocks are the same.
Thank you.
  • Pat Ramos Nov 27, 2007
    Thank you for your help. I appreciate it.
Zone-1 atlantic time
zone-3 central time
zone-4 mountain time
zone-5 pacific time
zone-6 yukon (alaska)
zone-7 hawaii
Posted on Nov 27, 2007
How do I set time zone? S/N: 502 16764PH.
Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there's nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet clock radio as follows: ZONE 1 - Atlantic Time ZONE 2 - Eastern Time (Default Setting) ZONE 3 - Central Time ZONE 4 - Mountain Time ZONE 5 - Pacific Time ZONE 6 - Yukon Time ZONE 7 To c h a n g e t h e d e f a u l t t i m e z o n e d i s p l a y, depress the TIME ZONE button. The number "2" will appear on the display indicating that the default zone is ZONE 2, Eastern Time. Hold theTIMEZONE button and then press either the or buttons your own time zone appears on the display, then release the buttons. The clock display will change to the correct time in the time zone you selected . The clock will always return to the correct time in the zone you selected after every power interruption. http://www.emersonradio.com/resources/owner_manuals/manual_1396274206.pdf
Apr 08, 2016 | Emerson Smart Set Alarm AM/FM Clock Radio...
Tip
Procedure For Setting Time Zones For Emerson Clock Radios
IMPORTANT: The first time you connect your new SmartSet® clock radio to
zone. If you live in the Eastern Time zone, there’s nothing else to do. Your
display to your own zone. You only do this one time and the SmartSet® will remember
interruption.
There are 7 time zones programmed into your SmartSet® clock radio as follows:
ZONE 1 — Atlantic Time
ZONE 2 — Eastern Time (Default Setting)
ZONE 3 — Central Time
ZONE 4 — Mountain Time
ZONE 5 — Pacific Time
ZONE 6 — Yukon Time
ZONE 7 — Hawaiian Time
To change the default time zone display, depress the Time Zone button.
The number “02” will appear on the display
Eastern Time
on Jun 12, 2009 | Emerson Smartset Clock Radio
How to set
Hello
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner
Mar 15, 2011 | Seth Thomas Radio-Controlled Howard Wall...
Time and outdoor temp not functioning
You probably need to set the time zone. Hit the set button until it shows the time zone (ie -7 MST), then hit the "+" button until it shows your time zone and the correct time. Continue hitting the set button to cycle through to the end of the settings.
Jun 24, 2010 | SkyScan 86709 Atomic Wall Clock
Cant fix the time zone
Successful reception of the time-synchronization radio signal is indicated by a radio waves icon to the right of seconds in the upper section of the display. After synchronization occurs, you can select your continental U.S. time zone (EST, CST, MST, or PST) by means of a switch on the back of the clock.
Feb 15, 2010 | SkyScan 86742 Digital Atomic Wall Clock
How do you set the alarm for pacific standard time on the emerson
Here is the procedure for setting the time zones for your Clock/Radio. Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time I will give you the web link for the owners manual so you can find any other information you might need for your Clock/Radio. (http://www.emersonradio.com/owners/iPod%20Series/iC200_042007.pdf) copy this web address and paste it in the address bard of your browser and it will take you to a pdf copy of the owners manual. I hope this information help you with your problem.
Apr 27, 2009 | Emerson Smartset Clock Radio
Time Zone Setting
Sorry it took so long to give you a answer to your problem. I hope this information help you with the problem. Thank you for using FixYa and have a nice day! Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time
Nov 04, 2008 | Emerson Smartset Clock Radio
Why won't it automatically set time?
Sorry it took so long to give you a answer for the problem.I hope this information help you with your problem.Thank you for using FixYa and have a nice day! Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time
Oct 21, 2008 | Emerson Smartset Clock Radio
Digital atomic clock radio
Hi. There should be a switch on top of the radio that allows you to select the time zone. It is just behind the snooze bar and labeled PST-MST-CST-EST. Try that.
Mar 31, 2008 | SkyScan 34202 Clock Radio
Correct Time Zone
Using the Emerson CKD5809C manual (also with SmartSet(tm) ), try Zone 4. TIME ZONE button: "04".
Zone 1: Atlantic Time
Zone 2: Easter Time (Default)
Zone 3: Central Time
Zone 4: Mountain Time
Zone 5: Pacific Time
Zone 6: Yukon Time
Zone 7: Hawaiian Time
Reference:
http://www.emersonelectronics.ca/emerson/en/category/list/694
or
http://www.emersonelectronics.ca/emerson/en/product/details/2361
As for disabling the Daylight Saving Time (DST) time change I have some guesses to try (not having one of these radios in my hand) or just skip to #4 below.
1. Manually setting the time and see if this disables the DST change.
2. Is there a Zone setting other than above? Like maybe a Zone 0? And then manually set the time.
3. Look at http://www.fixya.com/support/t236208-daylight_savings_time_adjustment for my solution there and try adjusting the DST Start to the same as DST End or DST Start and End with a month of 0 (if that is possible).
4. Or for the really desperate, change the Zone to 5 during DST and back to 4 during standard time (no worst off than with no DST auto setting.) (After I wrote this, I found an Emerson reference to no DST areas, Saskatchewan in this case, in the CKS1850C manual http://www.emersonelectronics.ca/emerson/en/product/details/2383, pg 9, and this is their solution.)
Oct 28, 2007 | Emerson CKS3029 Clock Radio
Emerson CKS3029 Clock Radio Logo
346 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
