Question about Panasonic DMR-ES10 DVD Recorder
DMR-ES10 DVD Recorder T112 error message
WIll no longer play DVDs.  Started getting a loud whirring/clunking noise every once in awhile, turned off and on or opened/closed tray and was then ok.  Now it happens every time I insert a DVD to play.  Also getting a T112 error message on the display.  Does anyone know what's going on o how to fix?
  • 1 more comment
  • mjstudio Oct 28, 2007
    I tried pressing ENTER - doesn't work.  It's hard to even get it to turn off or eject the disk.  I have to continually press OFF.  I have the manual and can;t find the T112 error message there either.  Less concerned about the display message and more concerned about what is causing the noise and wht it won't read DVDs anymore.  Any other thoughts?
    When I press ENTER the noise stops and I get a T112 message on the display.  It then allows me to eject the DVD and turn the unit off, but that's as far as I get.
  • kenako Jan 05, 2008
    Hi
    My ES10 has stopped recognising any discs that I put into it.(DVD's, DVD-RAM and DVD-RW )
    When I try and play any type of disc, the error message "No Read" comes up, and on the screen I get the massage saying "Disc not recognised"-please check disc. I've cleaned the lens to no avail, the machine constley goes into the "SELF CHECK" mode.
    Help?
  • 328 Answers
Can you press Enter when you get the error message? That will tell it to diagnose the problem. Tell me if that works. The manual can be found here. I can't find the T112 error you mentioned though.
http://panasonic.ca/PDP/OperatingInstructions/dmres10s-oi-eng.pdf
Reply if you need further assistance.
Posted on Oct 28, 2007
I have a Panasonic DVD Recorder DMR-ES10 that will not power up. Are their any fuses on this unit?
hi,
every electronic equipments comes with fuse in the input side for protection .ur dvds power supply may have some problem. check it before inserting the fuse.
ok
Dec 17, 2010 | Panasonic DMR-ES10 DVD Recorder
Have panasonic dmr-ez485v error message -NO READ- changed disks used prerecorded movie same as my recorded disks, hit reset - still no change
I just saw the date on this message and realize that it was awhile ago. I assume that you have dealt with it by now... So for others who are trying to fix their DVD player:
I have a DMR-EZ485V DVD player and just started getting the error message "No Read." I couldn't find an answer on the internet and finally called Panasonic's customer service, (there is no charge 1.800.211.7262). Since it says "No Read" to everything--store-bought DVDs, burned DVDs, CDs; AND when there is nothing in there (it acts like it is trying to read when the tray is empty), the customer service rep thinks that I am having a lens issue. It either needs to be cleaned (can pick-up a product at Best Buy or Radio Shack) or, if that doesn't work, the lens needs to be replaced.
Aug 09, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Copyright Message on Panasonic DMR-ES10-S
certain files are decoded w/ copyright protection not all
Aug 13, 2009 | Panasonic DMR-ES10 DVD Recorder
Can't record DVD+RW and DVD+ Disks...PLUS
Firstly, you need to finalize the -R disk recorded by and in your unit before it will play back anywhere else.
Secondly, the DMR-ES10 does not support +RW, only -RW.
Finally, I have never heard of a +D. Do you mean +R? It is likely that you have a corrupt disk; change it.
Mar 11, 2009 | Panasonic DMR-ES10 DVD Recorder
Panasonic dmr es15 dvd recorder
My Panasonic Recorder DMR-ES10, will not play discs sent to me from the U/K,
using a L.G dr275 recorder, onto a DVD+R disc, how can i overcome this problem. regards Tom Escott.
Aug 30, 2008 | Panasonic DMR-ES10 DVD Recorder
Revving noise-wont record
Turns out the rubber disc grip on the spindle simply needs to be cleaned (using an alcohol wipe). This is the part that holds the disc firm while it's spinning...the noise and failed disc reads comes from this rubber getting dirty and allowing the disc to slip. Total time to fix including disassembly was less than 15 minutes!
Aug 16, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic dmr es10
Some DVD recorders don't like certain types of media. Does this happen with all blank dvd+rw disks or just with that specific brand? If it's that brand then you should just use a different one.
Jan 07, 2008 | Panasonic DMR-ES10 DVD Recorder
Dmr-es10 dvd recorder panasonic
does it record?We have noticed that these problem is occured by dirt on optical .First you have to clean optical lens .take cotton sworb and open the dvd-ram assy ,open top cover and claen leser.If problem still persist than only solution is to change dvd-ram drive thats optical assy.
Dec 18, 2007 | Panasonic DMR-ES10 DVD Recorder
No read error
Hi All,
I've had the "can't read disc problem" and "noise" when the
disc is turning. It's not the lens. The rubber pad/ring that the
CD/DVD sits on gets "dirty" and doesn't grab the disc well enough
and the disc slips. It's especially a problem when recording, because
it can ruin the discs, and make then unusable.
I took mine apart and cleaned the rubber ring and that solves the problem.
(for a while anyway) I think the rubber pad has hardened and lost it's grip,
so I have to clean it more and more often now.
Cleaning
1) Unplug it (I take all the cables off)
2) Take the top cover off (5 philips head screws) Don't touch any of the electronics.
3) Remove the blk plastic DVD reader cover CAREFULLY (6 philips head screws)
Don't move any of the parts on the cover or it's really hard to put back together.
4) Gently wipe off the rubber ring with a damp lint free cloth
5) Put the blk cover back on, plug it in, and test it with a disc take make it sure works.
6) Put the metal cover on and you're done.
I used to work as an electrical engineer so I feel comfortable taking this kind of stuff
apart. If you don't, you can buy a new one or have someone else clean it.
Goodluck
Jun 12, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES10 DVD Recorder Logo
225 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
