Question about Lexmark Polaroid P310 Photo Printer
P310 printer My printer is connected with usb cable to front of my computer.  It powers on and will print a test page from the printer, not through the computer.  I no longer have a driver disk, if one came with it.  I can't get my computer to recognize it, I think because I need the driver.  Can anyone give me a connection to get the driver for this printer?  email glhjrhfac@yahoo.com  Thanks for your help.
  • anab Mar 08, 2008
    it just won't print!!!!
This printer cannot connect to a computer. You need to connect it directly to the camera using the USB cable provided with the Camera
Posted on Nov 30, 2007
Myy Brother MFC5460 will not print at all. Printer status says it is ready, but the printer never receives the print material. The information remains in the print queue. Work Offline is not checked, so I...
How is it connected?
If its connected via usb cable just follow the steps below:
1. Make sure that Mfc5460cn lcd shows date & time. 2. Disconnect the usb cable from the computer and printer. 3. Turn off the printer and unplug it from the power outlet. 4. On the computer, cancel the document on queu. Go to printers folder and right click on the Mfc5460cn icon and left click on cancel all documents. 5. Reconnect the usb cable from the printer then to your computer. Make sure that it is connected securely. 6. Plugged the printer back to the power outlet and then wait for the lcd to show date & time. 7. Open the printers folder again. Make sure that the status is ready document 0 8. Right click on MFC5460cn then left click on properties. ON the lower left side of the window click on print test page.
The printer should print a test page. And it should work,
Hope this helps. Rate if it works. Thanks
Apr 09, 2011 | Brother MFC-5460CN InkJet Printer
Prints test copy every time I switch it on.
All right so you are getting print test copy every time you turn on or switch on your printer. You can follow the following steps to fix this issue:-
1.. Turn off the printer and wait 10 seconds. Turn it on again
2. Let the printer print the test page.
3. After the test page is printed, disconnect the USB cable connecting the printer to your computer. DO NOT turn off the printer while disconnecting the USB cable.
4. Place the test page on the scanner glass and press the SCAN button on the printer. The ON light will flash as the page is being scanned.
5. Remove the test page when the ON light is steady.
6. Finally, turn off the printer and wait another 10 seconds. Then turn it on again. No more printing test pages! Yay!
(You may now reconnect the printer to your computer via the USB cable.)
let me know if it fix this issue and helpful to you.
Mar 03, 2011 | HP PSC 1510 All-In-One InkJet Printer
Hp deskjet 3650 printer works very slowly with win 7
tion one: Check the power supply Follow these steps to check the power supply to make sure that it is functioning correctly.
  1. Turn the product so that you can access the rear side.
  2. Unplug the power cord from the back of the product. Figure 1: Unplug the power cord from the back of the product
  3. Remove any devices between the product and the power outlet, such as surge suppressors or power strips.
  4. Plug the power cord directly into a wall outlet.
  5. Print and time a self-test again.
  • If the test page prints in 30 seconds or less , the problem relates to the power supply. Replace devices between the product and the power outlet, or leave the product connected directly to the wall outlet.
  • If the test page takes significantly longer than 30 seconds to print, continue to the next solution in this document.
Solution two: Check the USB connection
  1. Disconnect the USB cable from the back of the HP product. Figure 2: Disconnect the USB cable from the back of the HP product
  2. Disconnect the USB cable from the back of the computer.
  3. Wait five seconds.
  4. Reconnect the USB cable to the back of the product and the computer, according to the following guidelines: The icon on the USB cable (c01424575.gif ) faces up when the cable connects to the product correctly. Connect the small end of the USB cable to the back of the product Connect the other end of the USB cable to the computer
  5. After you make sure that the USB cable connects correctly and securely, review the following guidelines to check other potential USB-related problems:
    • USB ports on the keyboard. USB ports on the keyboard and in the front of some computers might not be powerful enough to support the product. If the USB cable connects to the USB port on the keyboard, try connecting it to another available USB port on the computer.
    • USB cable length. HP supports USB cables less than 5 m (16 feet, 5 inches) long. However, a USB cable that is 5 m (16 feet 5 inches) long must be of high-quality. Otherwise, HP recommends using a USB cable that is less than 2 m (6 feet, 6 inches). Do not use patch cables to increase the length of an existing cable. Use a powered USB hub if you need more length.
    • Alternate USB ports. Connect the USB cable to another port on the computer to make sure that the USB port on the computer is not the problem.
    • Defective USB cable. Replace the USB cable to make sure that the existing cable is not defective.
    • Conflicting USB ports. Disconnect any other USB printers, USB scanners, USB cameras, and any other USB connected peripherals. Start reconnecting these devices one at a time to determine if one of the devices is using too much power. Consider purchasing and installing a powered USB hub if necessary. NOTE: A USB-powered hub is a device that increases the number of available USB ports on a computer and facilitates communication between the USB devices and the computer. A powered USB hub can resolve communication failures between some, but not all, USB chipsets and HP products.
  6. After checking the USB connection, print and time a self-test page again.
  • If the test page prints in 30 seconds or less , the problem relates to the USB connection. Replace the USB cable or modify the connection to meet the preceding criteria.
Solution three: Check cartridge compatibility Incompatible cartridges can cause the slow printing problem. To check the cartridge compatibility for your product, go to HP SureSupply . To identify your cartridge in a language other than English, click the language link near the globe icon (c01906983.gif ) in the upper right corner of your browser. Examine the cartridges in your HP product, and then follow these steps to check which cartridges are compatible with your product. The number on the cartridge label must match the numbers listed on HP SureSupply.
  • If the cartridges are not compatible with your HP product , replace the cartridges. You can order replacement cartridges directly from HP SureSupply.
  • If the cartridges are compatible with your HP product , continue to the next solution in this document.
Solution four: Perform a reset A reset drains the power from the product and returns it to the same settings after restarting.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Unplug the power cord from the back of the product. Figure 3:
  3. Disconnect the data cable (USB or Ethernet, depending on how your product is set up) from the back of the product. USB cable Ethernet cable
  4. Unplug the power cord from the wall outlet. Figure 4: Unplug the power cord from the wall outlet
  5. Wait about 30 seconds.
  6. Reconnect the power cord to the product and wall outlet, and then turn on the product.
  7. Print and time a self-test again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Mar 31, 2010 | HP DeskJet 3650 InkJet Printer
PRINTER WILL PRINT COPY OF SOMETHING BUT WANT PRINT SOMETHING OFF COMPUTER.
This problem sounds like the printer is not set up properly on the computer. Have you installed the software that came with it? If so, look for the printer under control panel and then try a test page. If the test page doesnt work, how is the printer connected to the computer, by USB cable? If it is connected by usb, try shutting the computer down, unplugging the usb cable, restarting the computer and once it is fully started, plug the usb cable for the printer back in. Do you hear a tone after the printer is plugged in? If so try to print again.
Aug 11, 2009 | Office Equipment & Supplies
Only test pages print perfectly!!
If when you print a test page it comes out perfectly, that means that the printer works, and the problem is communication between the printer and Mac.
Try the following:
Start testing a different USB cable and a different port.
Unplug Mac, and eventually remove the battery.
Unplug the printer power cable and USB.
Put the mac back toghether and restart it with printer usb not connected.
When mac is on, reinstall printer software driver, with Mac still not connected to printer, using printer disk or download.
Connect printer to Mac when asked by software.
If that still does not work, test the printer on a different computer, even if it is not common, the printer may have a faulty USB port.
Feb 28, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printer not working when hooked up to notebook
uninstall the driver completely,reboot the system,again install the driver first,connect the printer afterword.
thnx N
Jan 29, 2008 | HP Deskjet 3845 InkJet Printer
Lexmark Polaroid P310 Photo Printer Logo
290 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
