Question about CyberLink SW- DVD Software Power DVD (SWPOWERDVD) DVD Drive
Cyberlink Power DVD 5.5
I am trying to reinstall this software and when it get's to 61% it says catastrofic failure and wont launch.
  • 382 Answers
Which software? Try going directly online ( not using the drive ) and getting the driver from the manufacterer.
Keep me posted.
Posted on Oct 28, 2007
I lost cyberlink powerdvd 12 activation key
Uninstall software and then reinstall, it should be fine.
Oct 03, 2013 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Code error
Before following the suggestions given below please make sure that you have the latest firmware for your DVD burner drive. Please contact your vendor or visit the manufacturer's website for the latest updates.
Please follow the steps mentioned below to resolve the issue:
1) Empty the contents of the C:\Windows\temp folder and C:\temp folder, if you have one. Then empty Recycle Bin.
2) Defragment your hard drive. DVD video files are very large and can quickly fill your hard drive to capacity. A fragmented hard drive can cause problems during DVD burning. Make sure to defragment your drive(s) regularly.
3) To avoid any compatibility issues, please close all other software and utility applications including virus scans, screen saver and instant messaging software before you launch PowerDirector.
4) Increase Virtual memory :
1. Right click on "MyComputer"
2. Select Properties -> Advance
3. Click on "settings" under Performance.
4. Select "Advance"
5. Click on "change" under Virtual memory.
6. Select "Custom" and enter initial value as "512" and Max value as "3096".
NOTE: If your existing settings are higher than recommended then leave them as before.
5) Please check whether the drive where you have installed Power Director software has enough space on it. At least 15 GB of free space is required and recommended while burning a DVD.
Now, try to burn the DVD at low burning speed.
If the issue still persists, try to uninstall other CD/DVD burning software like Nero, EasyCD Creator, Direct CD etc. Two burning software installed on same computer are known to cause conflict due to common files in them.
Also disable the XP built-in burning software. To disable the Windows built-in burning software:
- Open My Computer.
- Right-click your CD-RW or DVD drive and click Properties.
- Select the Recording tab.
- Remove the check mark from the 'Enable CD recording on this drive' check box.
- Click OK.
Also make sure that the total size of the video does not exceed the disc limit. (It is recommended that the total size should be less than 4.3 GB)
Now, close all other software and utility applications and then try the 'Create a DVD folder' option in the burning options screen and let us know of the result.
If the DVD folder is burned successfully, then the issue is burner specific and not software specific.
If the issue still not resolved, you may need to reinstall the Power Director software. Uninstall other burning softwares and then reinstall Power Director.
Follow the steps given below to reinstall your PowerDirector. Before installing your program, please close your MSN messenger, since we found that MSN messenger my lock some installation programs.
i) Uninstall PowerDirector software:
a.)Start--> Programs -->Cyberlink PowerDirector --> Uninstall PowerDirector
b.)Start --> Run --> type "regedit" --> click "HKEY_LOCAL_MACHINE" --> click
"Software" --> click "Cyberlink" --> "PowerDirector". Delete folder "PowerDirector".
c.)Start --> Run --> type "regedit" --> click "HKEY_CURRENT_USER" --> click
d)Reboot your PC.
ii) Reinstall PowerDirector. (NOTE: Before installation please close MSN Messenger, if open)
Now try again to 'Create a DVD folder'.
Go ahead with burning DVD only if the DVD folder is created successfully and without errors.
Jan 24, 2008 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
I have been using Cyberlink Powerproducer Express for many years which after producing the appropraye files, it passes down to and opens Cyberlink - Power Producer 2 Gold to generate the DVD. For some...
If recently you have made any hardware or software changes eliminate that and then check how it works.
Do system Restore to a previous date when your computer was working fine to do that go to Start - all programs - accesories - system tools - system restore select a date when your computer was working fine follow the on screen steps.
if you have win vista then start-search type system restore and do the same thing.
If this doesnt helps try to uninstall and reinstall the software.
Jul 25, 2010 | CyberLink PowerProducer 2 for PC
I want to download
Download from
But, Version 10 (not '5') is _NOT_ "free" software, unlike the 'VLC' software for playing DVD-movies.
See: to download VLC.
May 31, 2010 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
It wont play any movies, msg pops up saying cannot play this dvd because of the current output display system.
Reinstall the program. Try it again, it should let it play your movies after you reinstall it.
Jun 25, 2009 | CyberLink Power DVD DX 8.0 for PC
I cant play dvd on my cyberlink powerdvd5
you can install vld software then you play the dvd.
Mar 10, 2009 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Unable to install a new powerdvd version
I imagine that it's trying to uninstall the older version to install the newer one, which it can't. NOTE: This is a desperate step. Delete the Cyberlink folder in C:\Program Files\; Go to Add/Remove Programs and attempt uninstall - it will say it can't uninstall, and ask you if oyu want to remove it from the program list. Click yes. Go to start->Search (or Find) and search for Cyberlink (make sure that Hidden and System files are being searched). Delete all Cyberlink files. Do the same, but with PowerDVD. Download and run CCleaner. Attempt to reinstall PowerDVD.
Nov 09, 2007 | CyberLink SW- DVD Software Power DVD...
Computers & Internet Logo
591 people viewed this question
Top CyberLink Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
