Question about RCA P52926 52" Rear Projection Television
Tv not working
We have a 1992 rca 52" projection tv,it was working fine then it made a weird popping noise almost like a crackiling then it went out.when we plug it in it makes a similiar noise but theres no picture or sound,what do you think the problem may be?,not
  • 4 more comments
  • tittle Oct 31, 2007
    the model number for my television is p52151st and chassis # is ptk169ptb,serial# is 233280381 i was,nt sure if you needed that info but i figured ide send it anyway,thank you for the info you gave me, i really appreciate it.you said you think it may be a bad hv divider block we,re gonna try that and see if it works thanks again
  • Anonymous Nov 17, 2007
    projection
  • maset1265 Nov 17, 2007
    projection rca tv model p52754at when power button is press light stays on for 5 seconds
  • cashman2007 Dec 02, 2007
    the tv just stopped working and when i went to turn it on it just makes a weird popping noise and it acts like it wants to turn on but it just wont.what do i do to fix it i have tried just about everything i can think of besides throwing it out the window
  • Anonymous Dec 18, 2007
    Went to turn TV on my wife thought she smell something like wire burning. The TV make a popping sound almost like a heart beat fro about 5-7 seconds then stops. No picture or sound.
    jrcordell721@comcast.net
    Richard Cordell
    Covington,Georgia
  • cdell721 Dec 18, 2007
    Turned TV on. Wife stated that she tought she smelled wire burning. We hear a popping sound much like if the TV has a heart beat. It last for about 5 to 8 seconds but no picture or sound.
    Genius:
  • 1,694 Answers
Probable bad HV divider block, part # 205064 ?
Need accurate info = Model / Chassis # 's........T.
Posted on Oct 30, 2007
  • Vista Electronics Oct 31, 2007
    HV  Block notes:
    1) Remove light box from TV
    2) Flip up PCB on CRT (front) side
    3) Locate HV block
    4) Unplug 4 or 5 ground wires,push aside
    5) Notice how RGB, input and focus wires are labeled and
        where they plug in----make notes...release /unplug wires..
    6) Make a hook from paper clip to retrieve rubber guide sleeve,
         one for each wire,four the same size,one slightly longer for
         focus lead....
    7) dis-mount old block....mount new block ( discard new plastic
        lock sleeves--originals work just fine....
    8) Make sure each wire has rubber guide sleeve...
    9) Re-install all wires as they were before--
    10) Fire it up!!!! Hopefully,you are done--if not-------
         Unplug RGB wires one at atime to see which CRT is bad!
        Please let me know.........T.
    8)
  • Vista Electronics Nov 19, 2007
    maset1265,
    Your solution will not match tittle.....please provide service #
    and I will supply accurate repair info................T.
I have a rca m50wh72s dlp tv was watching the tv one day and then herd a loud pop noise and the tv went black i try to turn it on it makes a funny rubbing noise like plastic on plastic and then the power...
Sounds like the color wheel or lamp I would check the lamp first to insure thats its not broken as they can make a pop when they fail sometime (Breaking) then I would check the color wheel you will be able to tell if the color wheel arear has the noise coming from it. If you need more assistance let me know.
Jun 13, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Will not turn on
If you replaced the FL231 without replaceing the DL231 it will usually work for a little while then fail. However if the sound youre hearing now is a short sharp chirp which coincides with the power indicator its often caused by a failed flyback and HOT Transistor, if the sound sounds like a soft psssst three times then DL030 and DL032 all items are on the Deflection/power board.
Jul 18, 2010 | RCA D52W19 52" Rear Projection Television
Rca P52921 52 in. projection made apopping noise
sounds like possibly the high voltage amplifier' just a guesas
May 08, 2009 | RCA P52921 52" Rear Projection Television
My 52 in rear projectiontv would not turn on
UNPLUG UR TV FIRST go to the back of ur tv on the right there should be a panal that has three screws or more this is were the power switch board is . remove it and check that there's no black marking's on it if there is that the problem
email - bfd.pete@hotmail.co.uk
Jan 14, 2009 | RCA D52W19 52" Rear Projection Television
Tv turned off and started beeping noise
Sound like high voltage splitter ( born or defected ) Am sure this is your problem. Or maybe fly back defected. Check for possible loose connections. Thank you !!
Jul 20, 2008 | RCA P52926 52" Rear Projection Television
RCA 52 PROJECTION TV MODEL P52151WK
No , if fuse was blown you would not get the popping. How old is unit ? It sounds like your high volt splitter. common problem with rca. repair should not cost more than 250.00. you will want to have chassis number  and manu date for help
www.classtorations.com
Jun 04, 2008 | RCA P52937 52" Rear Projection Television
RCA TV D52W19
Describe noise.. Chirping 3 times? does the led on front flash
Mar 06, 2008 | RCA D52W19 52" Rear Projection Television
Rca tv
I had this happen to mine and I had to have the high voltage transformer replaced. I took it all apart my self to save money and it only cost me about $285
Jan 14, 2008 | RCA P52926 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
167 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
